Sharp Carousel R530EST Microwave Oven Logo
A
Anonymous Posted on Aug 25, 2014
Sharp carousel microwave
Sparks
Nikhow
Level 3:
Dedicated:
Visited the website for 20 consecutive days.
  • Master 436 Answers
  • Posted on Aug 25, 2014
Nikhow
Master
Level 3:
Dedicated:
Answers
436
Questions
0
Helped
133540
Points
1221
Sometimes, bits of food get behind the microwave generator mica cover and cause this EXACT problem they short out the microwave energy and spark. . It is NOT broken but DONT let this happen for more than a few seconds. !!!! You will see the Mica (looks like plastic) cover from inside the oven and will be on one of the sides.It looks oblong normally, It is actually transparent to Microwaves and is how they get from the generator in to the oven. Give it a real good clean around the edges or better still take it out to clean. and it should be fine
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Apr 18, 2008
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
Anonymous
  • Posted on Oct 13, 2008
SOURCE: Where is the light bulb in an old Sharp Carousel Microwave?
Microwave_svc's site is awesome! I was able to get all the help I needed for a similar Sharp Carousel microwave. My bulb was simply loose in the socket base causing intermittent bulb lighting. Microwave_svc's helpful links got me to the service manual and, along with a nice set of "tamper-proof" screw compatible TORX bits I bought at HarborFreight, I was easily able to get cover off, remove bulb socket, tighten bulb, re-install bulb socket, button unit back up, and, voila, the light now works without intermittent blinking. FIXYA!!!!
Many thanks to guru microwave_svc!!!!!!!
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Nov 21, 2008
SOURCE: sharp carousel microwave doesn't spin
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
The best place to order Sharp parts is Tritronics. You can also call them at 866-779-5835
Anonymous
  • Posted on Dec 14, 2009
SOURCE: Wattage Sharp Microwave Ovens Carousel Model R-3A35
i just checked my R-3A36 manual to find out the wattage. it's 800 watts. i make pralines in my microwave. i am always asked for the recipe. so i needed to be able to tell people the wattage of my oven so they can adjust the recipe to their oven.
garry, metairie,la.
Anonymous
  • Posted on Mar 04, 2010
SOURCE: manual for sharp carousel R-230 AV
Please walk me through the defrost on my sharp micor
HOW DO i CHANGE THE BULB IN MY SHARP R-651ZM MICROWAVE OVEN
Changing the light bulb on your Sharp carousel microwave will allow you to have needed light inside the oven. Microwaves are not designed for consumers to change the light bulb due to manufacturer liability, but it can be done. Following the proper steps will ensure a successful installation. Step 1 Unplug the Sharp carousel microwave from the electrical outlet.
Step 2 Locate the screws around the outer cover of the Sharp carousel microwave and unscrew all the screws.
Step 3 Lift off the covering.
Step 4 Locate the bulb and unscrew. Screw in your new bulb.
Step 5 Replace the cover and screw back tightly. Once done, test your new bulb.
User manual for 1200 w carousel ser# 57088
Free Sharp Microwave Oven User Manuals ' ManualsOnline ...
kitchen.manualsonline.com > ... > Sharp > Kitchen Appliance Sharp
Products 1 - 50 of 359 - Sharp Microwave Oven 11452 User Guide. Pages: 0 Saves: 0 ... Sharp Operation Manual Microwave Oven R-308H, R-305H. Pages: 0 ...
Free Sharp Convection Oven User Manuals - Kitchen .
Sharp carousel R-930-AK microwave is sparking how to stop it afraid to use it
Sparking could be caused by something metallic inside the microwave! Check in side for anything metal like foil!
Manual pdf
manual can be download from several websites, just type in your search window like Google: Sharp #Model + "service manual download PDF" into the search field.
https://www.manualslib.com/manual/151473/Sharp-Carousel-R-9h76.html#product-Carousel%20R-9H84B
or,
https://www.manualslib.com/products/Sharp-Carousel-R-9h76-349741.html
or,
https://www.manualslib.com/brand/sharp/microwave-oven.html
2helpful
Sharp carousel R 430 EK 1200 watts
This is not good, the magnetron is arcing because metal is exposed, this will eventually destroy the magnetron making the oven useless. I strongly suggest it get looked at for safety and potential fire hazard.
2answers
User Manual Needed for Sharp Carousel Microwave Model R-303CW
mcdevito75 here, Best Bet, contact Sharp online, try sharp microwave oven.com Or in any store that sells Sharp microwave ovens get contact info off that package.
1helpful
R-425LS 1100 Watts Microwave Oven: I need a manual for the sharp carousel R-425LS...
http://www.sharpusa.com/~/media/186C050CCE1F4A99ADC5FA230942E483.ashx
R-1214 Stainless Steel 1100 Watts Microwave Oven: turns on buts starts sparking in a few seconds. ...
what's sparking... is it by the Magnatron window... or the carousel?...
If there is a carousel... take it out...
if its by the magnatron window,,, then...houston... we have a problem...
might be contamination... and that may require opening up the unit... sorry...
hopefully it's only something floating around in there that's causing the arc...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
Top Sharp Microwave Ovens Experts
woodzowl307
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
