Kyocera Mita Toner 37085011 for DC-3060 & DC-4060 Copiers Logo
A
Anonymous Posted on Aug 21, 2014
M559200308 what kind of copier is this?
Ezewudo Onyekachi
Level 3:
Master:
  • Master 425 Answers
  • Posted on Aug 22, 2014
Ezewudo Onyekachi
Master
Level 3:
Master:
Answers
425
Questions
7
Helped
85420
Points
1141
It is not a colour copier and uses toner cartridge.
How do I connect my computer to a Copystar CS-5035 Copier/printer? It does not appear to be a regular USB connection in the back. The specs for CS-5035 read Parallel IEEE 1284 or High Speed USB 2.0.
All 2.0and 3.0 Will work just fine . there should be a cable supplied with the copier . With a fitting to fit the copier at one end a USB fitting at the other end to fit the computer .
What kind of glass is used for copier platens? I can replace a broken one myself if I can get the right kind of glass.
Try ordering the glass from the parts department of the manufacturer. That way you'll know the glass is the correct type and size.
End of the program is not at al
What kind of program are you trying to run????? Is it for a copier? If so, can you let us know what kind and model. It help's to take the guess work out of the question.
How do i empty a waste toner bottle on a lanier color copier
What kind of copier is it? On many of the Lanier color copiers, the waste toner bottle is located on the lower left side inside the front door.
Turn the copier off first. Pull the big front door open and turn the bottle with the oil to the left -- the waste toner bottle is the plastic gray tank behind that. Slide it out (carefully) and dump it in a plastic trash bag, then reinsert it.
If you have a different kind of copier, please specify the model and I'll tell you how to get to the waste toner bottle.
Heater Unit & Hard Disk problem ir3300
1) what kind of hdd failure? Did copier report error code like E602-0003, or? When the hdd error occured did the service exchange HDD with new one and upgrade the system. Other thing, but not mostly likeble, check the current in el. insert.
2) Wich kind of problems? Did the copier reported E000, E001, E002, E003,..., is there was smudged copies, paper jams,..., how did you solve the problem? Did the service replace fixing film unit, or complete fixing unit? Do you have enough air flow around the copier, is the copier beneath the air conditioning device, is there any air draft,...?
If you want you can contact me on emma.servis@gmail.com, for more help.
Need to clear the memory of a Ricoh Aficio 1232c copier, it is printing out random copies of some kind of code, can't find manual...help.
you do not need to clear the memory print the configuration page and see which driver is supported:
it can [RPCS] or [PCL 5e] or [PCL 6e] or [PostScript]
if you are using the driver which the machine does not support she will print documents as you say some kind of codes.
How to Stop the Counter
you can't stop or reset the counter.
Transparency - can I use one in my copier and if so whick kind?
Just make sure to get transparency sheets that are designed for your kind of printer. Either inkjet or laser.
The sheet's should say if they are for use in inkjet or laser on the box.
3helpful
3answers
Reset Xerox Copier Machine model No. 5825
your copier should be displaying a fault code, different codes need different reset codes - be specific
Top Kyocera Mita Office Equipment & Supplies Experts
Sudeep Chatterjee
Sudeep Chatterjee
Norman Weimar
Norman Weimar
Ngoro
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
