Euro-Pro Fast and Easy 420 Mechanical Sewing Machine Logo
Steve Madrigal Posted on Jul 24, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sewng machine fails to loop on bottom bobbin
Machine fails to loop thread on bottom bobbin
Richard Schabler
Level 2:
Novelist:
  • Expert 109 Answers
  • Posted on Jul 25, 2014
Richard Schabler
Expert
Level 2:
Novelist:
Answers
109
Questions
Helped
66531
Points
325
There are several possible causes for this problem.
Simplest first.
1) The machine has sat in the closet for three or more months, and the oil has ceased. The fine oil requried for these precision machines does run away, and/or cease up into a grease like paste, causing the parts that move in precise harmony, to be not so precise.
The cure for this, is to remove all thread and fabric, and run the machine full speed for about two to five minutes. This heats up the parts and loosens up ceased parts. A good re application of fresh oil helps too.
NOTE: Check the needle is Straight by turning the machine a couple of turns by hand and seeing that the needle dosn't hit any metal parts. A breaking needle can cause dammage to the machine or user in when operating at high speeds.
2) Tension dials have been knocked out of balance. There is a numbered tension dial on the front of the machine, somewhere along the threads path from spool to needle. if this is too tight, the thread will not leave a loop big enough to catch the bottom thread. Be sure this is set to about 3, usually. It should be adjusted while stitching, when you get to that point.
On the bottom thread, on the Bobbin Holder piece that comes out of the bottom, there is a small screw that adjusts tention of the thread comming out. This screw should not be tight, but tight enough. Completely by tactile intuition, this screw should be adjusted to allow the thread to slide out of the bobbin holder smoothly. It must have some tension to pull the thread from it, but not so much that it is noticeable, or take much of a grip on the thread to pull it out. (difficult to describe)
These two tensioners must balance so the threads, cross paths, but also pull the stitched snugly into the fabric being sewed.
3) Bent Needle, this is a problem if the fabric being sewed has pulled the needle off it's center. If it is not perfectly straight, don't use it.
4) Cheap thread can be a problem. If the thread is frayed, or fuzzy looking, it may be that it will not work with as fine a needle you are using. Needles have various sizes and sized holes to feed the thread through, a fine needle needs fine thread, and coarse thread needs a larger needle.
These are the primary causes of the threads not looping together properly. I hope this helps.
5 Related Answers
A
Anonymous
  • Posted on Dec 14, 2007
SOURCE: Yet another stitch tension problem...
Thank you, thank you! I just tightened the screw on my bobbin case and that instantly fixed my thread tension problem. How on earth are you supposed to know about the little screw?! I thank you so much for the tip!
Anonymous
  • Posted on Aug 13, 2008
SOURCE: the bobbin thread on sewing machine will not catch
how do you retime
Anonymous
  • 3 Answers
  • Posted on Feb 19, 2009
SOURCE: i dont understand what it means by...
I beleive what they are asking you to do is to bring up the bobbin thread to the top of the throat plate( which cover the bobbin area, to do this you hold the top thread end and manually turn the wheel to engage the bobbin thread and bring it to the top of the throatplate, now you should be ready to sew
Maryann Sosewhappy
Anonymous
  • 25 Answers
  • Posted on Jun 15, 2009
SOURCE: thread caught in hook race
There should be a small screw on the side of your bobbin case adjust it little by little until you get the correct tension.
durantheman
  • 148 Answers
  • Posted on Oct 03, 2009
SOURCE: Top thread gets stuck around bobbin case
you might have a bent needle
Top Euro-Pro Sewing Machines Experts
vince
Ngoro
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
