Thx for the help with time set but how do i now set the timer on the fujitsu ar-ry3 model with the remote? cheers any help would be appreciated
SOURCE: my fujitsu inverter does not cool below 18deg C
Heya Mark,
Fujitsu air cons are factory set at 18degs you cannot change it without going through all the controller programs. Normally air cons are serpose to run around the 20deg point, is the air con not running effectually or do you just really like it cold.
I could check with tech help and see if I can send you the derictions of changing the minimum set point but it will not be good in the long run for your unit
SOURCE: hOW DO I SET THE
Right above the 'CLOCK ADJUST' there is a small hole, you need to push a ballpoint pen or something into that hole, to allow you to set the clock using the - and + buttons next to it. Then press the pen into that hole again in order to finalize the time.
SOURCE: How to change the time
