GE Profile Harmony DPGT750GC Gas Dryer Logo
A
Anonymous Posted on Jul 21, 2014
Error code reads "there is a problem with the model connector" on my GE Harmony dryer DPGT750GCWW. How do I fix it?
5 Related Answers
brian smith
  • 27 Answers
  • Posted on Nov 01, 2007
SOURCE: GE Profile Harmony dryer error message
PCB is probably the printed circuit board. you'll need the model# off the dryer (not from the manual), then go to GE's website to get an idea of the cost ($150-200). It's located under the control panel of the dryer. GE calls it 'PWR/PCB ASM-MAIN'.
Is the dryer still under warranty?
Anonymous
  • 54 Answers
  • Posted on Jul 04, 2008
SOURCE: GE Profile Harmony Gas Dryer DPGT750GC1PL not heating
If you hear the blower ramp up when you start the dryer and it slowly ramps down or quits all together then you need to replace the blower.
Anonymous
  • 6784 Answers
  • Posted on Jun 06, 2009
SOURCE: GE Harmony electric dryer model DPGT750EC1PL- very
Check the following to address this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
dragonsthatk
Albert Getty
  • 547 Answers
  • Posted on Jul 19, 2009
SOURCE: ge profile harmony electric dryer doesn't always heat.
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Anonymous
  • 10319 Answers
  • Posted on Mar 12, 2010
SOURCE: GE profile harmony dryer has power, drum turns,
check out the ignition spark ignitor
that makes the burner to heat up
Top GE Dryers Experts
vince
Axel Gringmuth
Are you a GE Dryer Expert? Answer questions, earn points and help others
