Woods Industries 59377 Indoor Digital Timer 7-day Logo
A
Anonymous Posted on Jul 09, 2014
How do I Program a 49556 timer - Woods Industries 59377 Indoor Digital Timer 7-day
Gene Haynes
Level 3:
  • Woods Master 5,391 Answers
  • Posted on Dec 12, 2014
Gene Haynes
Woods Master
Level 3:
Answers
5391
Questions
0
Helped
2659358
Points
14125
1 Related Answer
Anonymous
  • 8197 Answers
  • Posted on May 28, 2011
SOURCE: Woods indoor timer . Model No. 49556/TE158WT I
Try the link below for the manual.
http://www.ccixpress.com/cci/Marketing/Woods_Canada_Timer_Instructions/49556.pdf
WOODS 49556
1) Copy following link for Woods TD1300 and 49556:
http://waterheatertimer.org/Woods-timers-and-manuals.html#49566
2) Many timers have different numbers. In the case of Woods timers, different numbers are sometimes different packaging at wholesale level: If package contain 1 timer, then 1 model number applies. If package contains more than 1 timer, then different number applies.
3) Add a comment Feb 2013, and describe problem you have with timer.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Can't figure out how to set Cat. # 49556/TE158WTA cannot find my manual
Open following link to identify 49556 timer:
49556 Manual:
http://waterheatertimer.org/pdf/Woods-49556-TD1300.pdf
If the TE158 is not same as manual shown, then review Woods page for same-similar timer, and then add a comment with clear description of timer for possible information.
1helpful
Woods timer Cat349556/TE158WTA 15a 1875W How do I set it (no manuel) Neil Coulter neilcoulter@sympatico.ca
Timer is not identified:
1) Woods 49556:
2) Add a comment with in-focus photo of timer posted on Flickr
3) Open following links for setting analog timer and/or identifying timer:
http://waterheatertimer.org/How-to-set-timer.html
Add a comment for more help
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
1helpful
I lost the installation & how to program infomation.
Woods in-wall 59018 is programmable timer:
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
Woods 59203 plug-in timer is programmable:
http://waterheatertimer.org/pdf/Woods-59203.pdf
Woods 59337 plug-in timer is programmable:
http://waterheatertimer.org/pdf/Woods-59377.pdf
Older style Woods 49556 plug-in timer is programmable:
If your timer is not listed, add a comment with description of timer
4helpful
Hello, I have model 49556/te158wt and I'm not able to set hour ! could you help me ?
Link above is the Woods 49555 manual
If the timer will not program, then it has gone bad.
Plug timer into wall receptacle
Back-up battery will charge in about 1-2 hours > if battery will not charge, then timer is no good
Some digital timers require back-up battery to be fully charged before display will show
Back up battery allows programming while timer is removed from receptacle
After timer is programmed, plug timer back into receptacle
Timer buttons show below
To set current time:
Depress RST (Reset) button to clear programs
Press-and-hold TIME button to select 12 hour or 24 hour display
Press-and-hold SET button. Mo Monday will flash in display
Push arrow button until current day shows
Press SET button again. Hours will flash
Press arrow buttons until current hour shows (am or pm)
Push SET button again. Minutes will flash.
Press arrow buttons until current minutes show
Programming ON-OFF
Make a schedule so programs don't conflict
You can set up to 20 on-off programs over 7 days
Each program has ON time Day Hours and Minutes
Each program has OFF time Days Hours and Minutes
Press right-arrow > PROG 1 ON flashes
Press SET > choice of day groupings flash
Press arrow button to select days
Press SET > program1 ON times flash
Press arrows to set ON time
Press SET > program1 for Hour
Repeat sequence described above to set MIN
Repeat sequence to set OFF times for program1
Repeat sequence to set Program2 thru Program20
Press TIME button to finish programming
Top Woods Hardware & Accessories Experts
jdthefixer
vince
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
