Heating & Cooling Logo
A
Anonymous Posted on Jul 07, 2014
H6 error code - Toyotomi Heating & Cooling
1 Related Answer
Pathan imrankhan
  • Posted on Apr 11, 2018
SOURCE: onida split Ac H6 error
Onida split ac trip H6 error Showing
My dawlance split AC 1.5 ton shows H6 within 30 sec of starting ...and stop working... plz tell me reason
I found this:
he H6 error code means the outdoor compressor motor position detection sensor error which needs an inverter tester to check it and probably replace it…
I.e, either the reason is wire gets disconnected or a temperature sensor is faulty
Lloyd split ac error code H6
H6 Lloyd ac fix this error
Input voltage low check
& Boler motar speed
Boler motar check capacitor
2answers
I have an error code H6 showing on my Defy Maximaid 800. Not showing in manual. What do I do. Checked all pipes. Cleaned out the filter. Thanks.
It's the cable that goes to the heating element. It gets burnt/corroded. Rejoined mine and it's working perfectly now.
Onida split Ac H6 error
2answers
Error code h6 my ac split electrulux?
H6 indoor unit fan stall.
Most likely a faulty fan motor but could be a faulty controller board. My money is on the fan motor which is a DC motor.
Voltas ac showing H6 code what?
My voltas sprit ac h6 code please help for
3helpful
Daikin error code H6 Outdoor Compressor motor position detection sensor error
sir
daikin inverter air conditioner we are replace the indoor pcb then next it gone out door pcb,next we are replaced outdoor pcb also then compressor not working oftre last we are replaced compressor then it will be giving H6 ERROR CODE please give me suggestion
Canon 5870 error code
What is and how do you clear error code H6-00
15helpful
3answers
Washing machine fault
im having the problem now with my daewoo that every time i put a wash on its giving me a H6 message error
Top Toyotomi Heating & Cooling Experts
ADMIN Andrew
ADMIN Andrew
Anonymous
Level 1 Expert
Anonymous
Level 1 Expert
Are you a Toyotomi Heating and Cooling Expert? Answer questions, earn points and help others
