Sharp 026 • 091 • 129 • 141
the guide can be retrieved from
http://www.comcast.com/MediaLibrary/1/2/CM/VanityURL/documents/us_electronics_uf4200c_manual.pdf
On the remote control, press and hold the appropriate mode key (TV button) until the four mode
keys flash twice. The mode key will continue to flash.
Enter the three-digit code. See above I gave all the Sharp codes.
After you press the first digit, the mode key should light and stay on. After you press
the last digit, the mode key should flash three times and turn off.
If the mode key does not flash three times before turning off, the code is invalid for
this device type. Repeat the procedure with another device code.
Point the remote at the device and press
POWER. If the device turns on or off, you
have finished programming.
If you have tried all the codes listed for the manufacturer and the device does not
respond, refer to the CodeScan™ section later in this manual.
