Timex T5K018 Ironman Triathlon 30 Lap Flix Watch Logo
A
Anonymous Posted on Jun 29, 2014
How to reset memory
Reset memory
Watch says the memory is full and I cannot start the time
Once you reset the watch then connect to PC and on Garmin connect you should see the memory then clear back down. Make sure all files when plugged in are either backed up or cleared.
Hi, my nike triax cv10 watch is frozen, tried pressing all the buttons at once but no luck please help?
The display of your watch may "freeze" due to static electricity or recent battery replacement.
If this occurs, press and hold all four buttons at the same time.
This will erase the data in the memory and allow you to reset the watch to the factory settings.
Press and hold all four side buttons at the same time to reset the watch to the factory settings.
Hope this helps.
Sep 14, 2013 • Watches
1helpful
Reset casio databank 150
remove battery and wait about two minuteslook http://www.pmwf.com/Watches/Casio/FirstMemoryProtectReset.htmand for other casio watches
Replaced battery and now no time
Have you connected the the battery case to the chassis of the watch (use a paair of tweezers).
This resets the time.
Has no display
Have the battery checked and the watch AC'd or reset.
1helpful
Manual for Smash Brand Watch 05-0407
You need to reset your watch completely and to do that, you have to start from battery.
Extract watch battery completely and leave your watch without energy supply for an hour. This will erase any data kept in watch memory.
Then put the battery back in watch exactly the way it was and reset your watch using your manual.
Unfortunately I can't help with manual as the original is the best you can get.
Don't forget to rate, please.
Top Timex Watches Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Paul Bade
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
