Garden Logo
M
Mike Campbell Posted on Jun 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HELP When I depress the clutch/brake and start tractor all seems good untill I start to release the pedel or try to engage the pto then it wants to die. I have tested the interlock switch and it tested good in both positions. 12.68 volts on the new batt. Can you help
Ron Stone
Level 2:
Sergeant:
  • Expert 408 Answers
  • Posted on Oct 01, 2018
Ron Stone
Expert
Level 2:
Sergeant:
Answers
408
Questions
0
Helped
115462
Points
562
Seat switch may be bad.
5 Related Answers
Anonymous
  • 37 Answers
  • Posted on Nov 23, 2008
SOURCE: mower dies when i try to engage blade
Hi, what you wrote is exactly what's is suppose to do. what is it about the mower that's not doing?
panilling9
panilling9
  • 284 Answers
  • Posted on Jun 08, 2009
SOURCE: craftsman model 917.272950 lawn tractor won't start
OPERATOR PRESENCE SYSTEM
Be sure operator presence and interlock
systems are working properly, If your
tractor does not function as described,
repair the problem immediately.
• The engine should not start unless the
clutch/brake pedal is fully depressed
and attachement clutch control is in the
disengaged position.
• When the engine is running, any
attempt by the operator to leave the
seat without first setting the parking
brake should shut off the engine.
• When the engine is running and the
attachment clutch is engaged, any
seat should shut off the engine.
• The attachment clutch should never
operate unless the operator is in the
seat.
Check your seat switch and clutch switch wires be sure that the connection to each switch is making contact and the mechanism that activates the switch is actually activateing them in other words be sure the clutch is pushing the switch in and your seat switch is occupied and be sure all grounding wires a intack
especially from your battery negative to the frame.You also could have a neutral safety switch which requires your transmission to be in neural.
try these things and let us know how we can further help from more of your input.
Anonymous
  • 138 Answers
  • Posted on Aug 17, 2009
SOURCE: riding mower dies when releasing brake
the seat switch is the problem. the switch itself could be bad, but usually theproblem is that the connector is just not plugged in all the way [by the way, trying to bypass the switch by inserting the wire doesn't work because there is a "switch" inside the connector to prevent you from doing just what you did]
richardlove4
  • 153 Answers
  • Posted on Oct 14, 2009
SOURCE: When I engage the front PTO the engine dies.
There is somthing in the PTO that is binding up. I am assuming the PTO is for the mower blades. The belt(s) could be binding up, not on the pulleys, etc. The blades should turn by hand easily.
Anonymous
  • 86 Answers
  • Posted on Apr 18, 2010
SOURCE: STARTS GOOD BUT ENGINE DIES WHEN CLUTCH RELEASED
cut the wires running to the switch...try again...if same, stripp back wires, and twist together...wrap in tape or use some sort of connector...it's electric and should be treated as such...try again...still ?? Start finding those switches and repeat the process til it works...theres usually 3 or 4...
Testimonial: "Haven't tried the suggested solution but makes sense."
Top Simplicity Garden Experts
wadingriver
wadingriver
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you a Simplicity Garden Expert? Answer questions, earn points and help others
