Ricoh Aficio 1027 All-In-One Laser Printer Logo
A
Anonymous Posted on May 15, 2014
How to reset the user code?
My center has Ricoh Aficio 2018D that was used by a prior director. Ask for a user code. no one knows the code. How to reset?
Helder Jose Da Costa Lameira
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Nov 04, 2014
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
0
Helped
19779
Points
33
There is two ways to achieve this, either enter servisse mode using yellow 1 0 7 and stop (hold stop for a few seconds) go to copy sp the go to 5 mode and the scroll to 801 memory all clear... this will reset the machine completely... if you not feeling so brave inside 801 there is sub menus just stroll down to clear UCS
5 Related Answers
Bubbabear64
Tim Babcock
  • 2794 Answers
  • Posted on Jun 30, 2008
SOURCE: Repair and service manual for Ricoh Aficio 250
Check with this website, they should be able to get you one
http://www.service-manual.net/ashop/catalogue.php?exp=&cat=283&gclid=COzWt96Ym5QCFSUqagodnl83tg
A
Anonymous
  • Posted on Feb 14, 2009
SOURCE: i am having trouble scanning
If the scanner has not been configured, or network settings have changed, the setup for scanning on this unit is unfortunately quite difficult for a novice. the manuals are readily available at Ricoh.com, under Downloads, but this will not help very much with the scanner config.
Sorry:(
Anonymous
  • Posted on Feb 24, 2009
SOURCE: ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Anonymous
  • 86 Answers
  • Posted on Mar 02, 2009
SOURCE: function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
  • Check and clean or replace the possible defective thermistors or out of position.
  • Fusing heaters open circuit.
  • Thermostats for open circuit.
  • Power supply unit.
Good luck and please rate me, thanks.
Bernard D'Souza
  • 165 Answers
  • Posted on Jan 16, 2010
SOURCE: Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Top Ricoh Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
