Konica Minolta Bizhub C550 Logo
Anonymous Posted on May 15, 2014
Error code c-0206 - Konica Minolta Bizhub C550
one_life_728
Level 2:
Habit-Forming:
Scholar:
  • Expert 71 Answers
  • Posted on May 15, 2014
one_life_728
Expert
Level 2:
Habit-Forming:
Scholar:
Answers
71
Questions
0
Helped
29263
Points
162
Class c code. Means steering and suspension or chassis group. Abs light or stability control code. Will have to have 10 to 15000 scanner to read code. If I had access to all data for flow chart. Or call dealership to to see if it just means a level sensor or whatever simple. It will tell u what circuit of what sensor is affected. Trace wires. 95% of electrical issues are from abrasive movent or being smashed. Visible check wires
If abs sensor code, check for loose wheel bearings or hubs. Do this by jacking anfd properly supporting vehicle and push and pull on tire with alternating movements with one hand on top of tire and the other on the bottom. If any play, check if in ball joints as well. Top ball joint will show play a long time before bottom joint. Chevy independent front ball joints have special procedures to check. As u
I’m happy to assist further over the phone at https://www.6ya.com/expert/christpher_f760d0f18f8eedc3
How do i resolve the issue of Konica Minolta Error Code C0202?
The error code C0202 indicates paper jamming in tray 1, C-O204: Tray-2, C-0206: Tray-3, C-0208: Tray-4. First of all, power off and unplug your copier, then empty paper from the problem tray and from the tray below it. Take out the problem tray, now you can see a paper jammed.
how to fix trouble code C-0202 error code in Konica Minolta ...
Videos as well
https://www.google.com/search?q=Konica+Minolta+Error+Code+C0202
1helpful
I'm looking sim lock code for my samsung d600e...\r\nplease help me.... thanks
Here's the list of codes
enjoy and dont forget to rate...
*#1111# ------------------ S/w Version
*#1234# ------------------ Dev.Version FW
*#2222# ------------------ H/w Version Rev
*#0206*8376263# ------ S/w Version ,Dev.Version FW,H/w Version Rev,time and Month and year flash *#0206*8378# ---------- Test Mode
*#4777*8665# ---------- GPRS Tool
*#0206*523# ------------ brightness of the display of 1-5
*#7465625# -------------- Interrogate - indication locks
*#0206*377# ------------ Error -- Table errors
*#0206*327# ------------ EEP(01/10)
*#0206*667# ------------ Debug mode
*#92782# ----------------- User agent (samsung-Sgh-G600/G600XEGH3)
*#232337# --------------- bluetooth addrnap uap lap
*#28837# ----------------- S/w Version BT and H/w Version BT
*#288378# --------------- Bluetooth Test
*#56658378# ------------ Look Test (Bomba code in a well-meaning words)
*#638738# --------------- Profiles Gprs- Inet settings (choice of various countries)
*#36245# ----------------- Test Mode (e-mail, mms, etc.)
*#0206*3768665# ------ DRM Tool (java, etc.)
*#777324# --------------- PPP TEST Menu
*#0673# ------------------ Mp3 Test Menu
*#0206*6366# ---------- Memo test
*#4378378# ------------- Gfs test
*#7378378# ------------- RESours Test
*#688# -------------------- Vod Test
*#64898378# ------------ NITZ test mode
*#898378# --------------- Timezone test mode
*#875108# --------------- FM Radio- speaker volume 1-10
*#52828378# ------------ Java Test Menu
*#73887# ----------------- Setup Wizard: (off/on)
*#2769737# -------------- Browser Test Menu
*2767*8451# ------------- Reset
*#738277# ---------------- Auto Profile Setting ( on/off)
*#0206*8376263# ------ S / w Version, Dev.Version FW, H / w Version Rev, time and Month and year flash
*#0206*8378# ----------- Audio Settings [menu (2) H / W test]*2767*688# = Unlocking Code
*#8999*8378# = All in one Code
*#4777*8665# = GPSR Tool
*#8999*523# = LCD Brightness
*#8999*3825523# = External Display
*#8999*377# = Errors
#*5737425# = JAVA Something{I choose 2 and it chrashed}
*#2255# = Call List
#*536961# = Java Status Code
#*536962# = Java Status Code
#*536963# = Java Status Code
#*53696# = Java Status Code
#*1200# = AFC DAC Val
#*1300# = IMEI
#*1400# = IMSI
#*2562# = ??? White for 15 secs than restarts.
#*2565# = Check Blocking
#*3353# = Check Code
#*3837# = ??? White for 15 secs than restarts.
#*3849# = ??? White for 15 secs than restarts.
#*3851# = ??? White for 15 secs than restarts.
#*3876# = ??? White for 15 secs than restarts.
#*7222# = Operation Typ (Class C GSM)
#*7224# = I Got !! ERROR !!
#*7252# = Oparation Typ (Class B GPRS)
#*7271# = Multi Slot (Class 1 GPRS)
#*7274# = Multi Slot (Class 4 GPRS)
#*7276# = Dunno
#*7337# = EEPROM Reset (Unlock and Resets Wap Settings)
#*2787# = CRTP ON/OFF
#*3737# = L1 Dbg data
#*5133# = L1 Dbg data
#*7288# = GPRS Attached
#*7287# = GPRS Detached
#*7666# = SrCell Data
#*7693# = Sleep Act/DeAct (Enable or Disable the Black screen after doing nothing for a while)
#*7284# = Class : B,C or GPRS
#*2256# = Calibration Info
#*2286# = Battery Data
#*2527# = GPRS Switching (set to: class 4, class 8, class 9 or class 10)
#*2679# = Copycat feature (Activate or Deactivate)
#*3940# = External loop test 9600 bps
#*4263# = Handsfree mode (Activate or Deactivate)
#*4700# = Half Rate (Activate or Deactivate)
#*7352# = BVMC Reg value
#*8462# = Sleeptime
#*2558# = Time ON
#*3370# = EFR (Activate or Deactivate)
#*3941# = External looptest 115200 bps
#*5176# = L1 Sleep
#*7462# = SIM phase
#*7983# = Voltage/Frequenci (Activate or Deactivate)
#*7986# = Voltage (Activate or Deactivate)
#*8466# = Old time
#*2255# = Call ???
#*5187# = L1C2G trace (Activate or Deactivate)
#*5376# = ??? White for 15 secs than restarts.
#*6837# = Official Software Version
#*7524# = KCGPRS
#*7562# = LOCI GPRS
#*7638# = RLC allways open ended TBF (Activate or Deactivate)
#*7632# = Sleep mode Debug
#*7673# = Sleep mode RESET
#*2337# = Permanent Registration Beep
#*2474# = ???
#*2834# = Audio Path
#*3270# = DCS support (Activate or Deactivate)
#*3282# = Data (Activate or Deactivate)
#*3476# = EGSM (Activate or Deactivate)
#*3676# = Flash volume formated
#*4760# = GSM (Activate or Deactivate)
#*4864# = Dunno doesn't work on newer versions
#*5171# = L1P1
#*5172# = L1P2
#*5173# = L1P3
#*7326# = Accessory (I got ********)
#*7683# = Sleep variable (
#*7762# = SMS Brearer CS (Activate or Deactivate)
#*8465# = Time in L1
#*9795# = wtls key
#*2252# = Current CAL
#*2836# = AVDDSS Management (Activate or Deactivate)
#*3877# = Dump of SPY trace
#*7728# = RSAV done# (Everything went to standart but nothing was deleted)
#*2677# = ARM State (None or Full Rate)
*#8999*636# = Have no clue what it is, i see 20 lines
*#9999# = Software version
*#8999*8376263# = HW ver, SW ver and Build Date
*#8888# = HW version
*#8377466# = Same HW/SW version thing
*#7465625# = Check the locks
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
*7465625*28638# = Auto Network lock ON
#7465625*28638# = Auto Network lock OFF
*7465625*28782# = Auto subset lock ON
#7465625*28782# = Auto subset lock OFF
*7465625*2877# = Auto SP lock ON
#7465625*2877# = Auto SP lock OFF
*7465625*2827# = Auto CP lock ON
#7465625*2827# = Auto CP lock OFF
*7465625*28746# = Auto SIM lock ON
#7465625*28746# = Auto SIM lock OFF
*2767*3855# = E2P Full Reset
*2767*2878# = E2P Custom Reset
*2767*927# = E2P Wap Reset
*2767*226372# = E2P Camera Reset
#*6420# = MIC Off
#*6421# = MIC On
#*6422# = MIC Data
#*6428# = MIC Measurement
#*3230# = Trace enable and DCD disable
#*3231# = Trace disable and DCD enable
#*3232# = Current Mode
#7263867# = RAM Dump (On or Off)
*2767*49927# = Germany WAP Settings
*2767*44927# = UK WAP Settings
*2767*31927# = Netherlands WAP Settings
*2767*420927# = Czech WAP Settings
*2767*43927# = Austria WAP Settings
*2767*39927# = Italy WAP Settings
*2767*33927# = France WAP Settings
*2767*351927# = Portugal WAP Settings
*2767*34927# = Spain WAP Settings
*2767*46927# = Sweden WAP Settings
*2767*380927# = Ukraine WAP Settings
*2767*7927# = Russia WAP Settings
*2767*30927# = GREECE WAP Settings
*2767*73738927# = WAP Settings Reset
*2767*49667# = Germany MMS Settings
*2767*44667# = UK MMS Settings
*2767*31667# = Netherlands MMS Settings
*2767*420667# = Czech MMS Settings
*2767*43667# = Austria MMS Settings
*2767*39667# = Italy MMS Settings
*2767*33667# = France MMS Settings
*2767*351667# = Portugal MMS Settings
*2767*34667# = Spain MMS Settings
*2767*46667# = Sweden MMS Settings
*2767*380667# = Ukraine MMS Settings
*2767*7667#. = Russia MMS Settings
*2767*30667# = GREECE MMS Settings
*335# = Delete all MMS Messages
*663867# = Dump Mm file
#*536961# = WAPSAR enable / HTTP disable
#*536962# = WAPSAR disable / HTTP enable
#*536963# = Serial eable / Others disable
#*53696# = Java Download Mode
#*5663351# = Wap Model ID [Your Model]
#*5663352# = Wap Model ID [SEC-SGH***X/1.0]
#*566335# = Wap Model ID [SEC-SGH***X/1.0]
*2767*66335# = Check on which model it is
*2767*7100# = SEC-SGHS100/1.0
*2767*8200# = SEC-SGHV200/1.0
*2767*7300# = SEC-SGHS300/1.0
*2767*7650# = Nokia7650/1.0
*2767*2877368# = Reset WAP Model ID to standart
77helpful
3answers
Sky remote code for lg 42LD450 42
hi code is 0206 works fine with mine
Ned a unlock code for samsung t-459
Amigos aca Tienen los codigos de ingeniero para hacer un reset general (El primer codigo es para eso).
El segundo es para subir el volumen y todas esas cosas.
* # 0206 * 523 #
El siguiente código es el menú de test. Dentro de este menú podemos mejorar el volumen del equipo haciendo lo siguiente:
* # 0206 * 8378 #
11helpful
2answers
Have a philips universal remote need to program a maxent tv
the code is 0206
Press and hold setup till light stays on
press TV button
enter 0206
press channel up
you are done
45helpful
3answers
Want to do a factory reset on my samsung e250
here are all codes for E250,
enjoy and dont forget to rate it as it will fix the issue.
*#2255# = Call List
#*1300# = IMEI
#*1400# = IMSI
#*7276# = Dunno
#*8462# = Sleeptime
#*2558# = Time ON
#*5176# = L1 Sleep
#*7462# = SIM phase
#*8466# = Old time
#*2255# = Call ???
#*7524# = KCGPRS
#*7562# = LOCI GPRS
#*2474# = ???
#*5171# = L1P1
#*5172# = L1P2
#*5173# = L1P3
#*9795# = wtls key
#*6420# = MIC Off
#*6421# = MIC On
#*6422# = MIC Data
regards
7helpful
2answers
1helpful
169helpful
9answers
How to increase volume in samsung E250
Try the code below at your own risk. I will not be liable for any damage this may cause to your phone.
Type the following codes on standby menu
*#0206*8378#
after typing you will be presented to a Test Mode menu
Select H/W Test
Select Audio Settings
Select IIS Normal (option 10) this is the normal volume for the phone. Scroll down to select Rx vol. then change level 14 to a higher value. Maximum is 30,000, i set mine at 5000
You can do the same for IIS Normal2 this is the volume for Music Player
2answers
Copier not working
Is the copier a Minolta? If so what model there are different ways to rest code.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
