Lanzar VIBE266 Car Audio Amplifier Logo
Anonymous Posted on Jun 23, 2009
I need help?
Ok well my problem is that i hooked the amp up and it has power to it and everything but i cant figure out why it will not put out the bass to the speacker. do u have a answer for my problem....
  • 1 more comment
  • Anonymous Jun 23, 2009
    lanzar vibe 226 and its brand new just got it 3 days ago and it is a aftermarket radio the amp kit is a scoshe kpa6 its running off of two 12in' xplod the subs are used but they work cause we tried it on another amp
    thank you ill try it out tomorow and see  what happens
  • Frank Fulton
    Frank Fulton May 11, 2010
    Is it installed to a factory radio (hi-level) or an aftermarket deck (low level rca)? Is the amp new? what kind of amp kit was used for installation? what kind of sub is it running? is the sub new? Post a comment and I can help you figure this out
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jun 23, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
14806
Points
18
Id check remote signal with a test light and also if there is a High pass or Low pass filter either on the head unit's settings or the Amp's controls
if your amp or head unit has a High pass filter setting enabled that would explain no bass being sent to your speakers,
if you are using a separate crossover to send the bass signal check those settings too..
if all else fails
test another amp on your system (if it works that would discard problems with the rest of the system's output)
Top Lanzar Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Sudeep Chatterjee
Sudeep Chatterjee
SmartAviator
SmartAviator
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
