You didn't say what make of printer it is. Error codes vary from printer make to printer make. Your best bet is to do a Google search for ERROR CODE 0310 NAME (NAME=name of printer).
The error code 0310 means the SOS signal is not detected within a given period of time after the output of the laser has been started.
To fix this clean the PH (laser) Unit by removing all the toner that gets inside. If that fails, you need to Replace the PH unit (p/n A034 R707 00). If the error returns again, replace the PRCB (p/n A034 H009 07).
Try any one of the following codes...Four digit codes : 0227 0233 0254 0264 0265 0266 0310 0325 The following codes specified in braces indicates the first one for the tv and the next for VCR. [0039 0252] [0147 0250] [0147 0257] Three digit codes :230, 456, [458 227]
well i have bad news for you.... your print head (laser) is bad.
CAUSE: The SOS signal is not detected within a given period of time after the
SOLUTION: Replace the PH unit (p/n A034 R707 00) and if the error returns,
This is a print head or laser failure. it needs to be replaced.
