SOURCE: Canon Pixma IP600D - error code 6502
What is the brand name and model of your printer? Make sure that your ink cartridges are precisely the correct cartridges for the brand and model that you are using. From what I have experienced ... if you try to use a used ink cartridge you will recieve an error.
Please refer to the following link http://www.coldreset.com/modules.php?name=News&file=article&sid=60
Terry
SOURCE: Canon MP630 error code 6502
Error 6502 is the ink tank position sensor error. Basically means the printer can't see the inks. Try reseating them. If this fails you need to send it back.
SOURCE: when printer is turned on error code 6502 comes on screen
Error Code 6502 appears generally after chaging a cartridge.
Solution:
All Best: Pineworks
SOURCE: error code 6502
This might work
Solution:
All Best: Pineworks
SOURCE: I have canon pixma proi 9000 I keep getting an
Hello
Follow the below steps in order to clear the error:
1.With printer OFF press and hold resume
2.while holding it down push and hold Power button
3.Release resume whilst still holding down power, the light should be green (not flashing)
4.Push resume once (orange) twice (Green)and a third time (orange)
5.release power button.
6.Then power it off and on again after it's finished making any noises and settled down.
Good luck.
