Pool & Spa Logo
A
Anonymous Posted on May 04, 2014
How do you turn a balboa spa on?
Got a used hot tub and im trying to get it going. Checked the pump out it rons but when i tried connecting it to the control circuit not getting any pwer. Is there some type of interlock or maybe transformer bad? Any suggestions?
Mike Tellegen
Level 3:
  • AO Smith Master 1,631 Answers
  • Posted on May 11, 2015
Mike Tellegen
AO Smith Master
Level 3:
Answers
1631
Questions
Helped
1028137
Points
5840
FYI...
Balboa does not make spas, just control systems.
but that is enough info to begin a troubleshoot process...
  • do you have anything displaying on topside control panel?
  • Fault codes?
  • When you say no power after connection to circuit what do you mean exactly?
  • Have you checked for burned system fuse?
5 Related Answers
Healeyman
mike kirschbaum
  • 1198 Answers
  • Posted on Apr 17, 2009
SOURCE: we have a spa quip 2.5 maxi flow spa pump,tried to
Hopefully you have not fried the motor. To free a stuck motor: try to reach past the strainer to the impeller and turn it. If you can't do that, remove the electric end cover and find a double flat for a wrench where the shaft goes into the motor. Or maybe you can remove the spring thing from the end of the motor and move the shaft with a pair of vise grips or pliers. Don't damage the place where the spring thing mounts. Don't try to move the motor with the plastic fan thing near the pump, you'll just break it, and then you really have problems.
To keep a motor from sticking, thru off season occasionaly spin the pump, just a few seconds will do, don't need water.
Anonymous
  • 4 Answers
  • Posted on Jul 19, 2009
SOURCE: intex saltwater chlorinator not working. Checked
IF YOU HAVEN'T HAD IT A YEAR , RETURN IT TO INTEX FOR REPAIR
Anonymous
  • 366 Answers
  • Posted on Feb 09, 2010
SOURCE: I have a 2004 great lakes hot tub with a balboa
check to see that the flow switch is working properly, it may not have enough flow on low speed to allow the heater to turn on. Make sure your filter/s is/are clean. If you have a pressure switch instead of a flow switch, it may need to be adjusted or replaced.
Coastsider
Charles East
  • 331 Answers
  • Posted on Apr 14, 2010
SOURCE: Hot Spring Spa pump won't run just click on circuit board....
Check for voltage at the pump, before assuming the relays are out... then check for voltage before and after the relay contacts
Anonymous
  • 6 Answers
  • Posted on Mar 31, 2011
SOURCE: Spa n a box 6
If the water pump is not circulating water you will want to do a simple procedure called "turning the impeller" You can call 888-997-6366 to be walked through this procedure over the phone.
Top AO Smith Pool & Spa Experts
john h
Kardoc
ADMIN Eric
ADMIN Eric
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
