Music Logo
A
Anonymous Posted on Apr 26, 2014
Behringer ms40 no sound from left speaker
Vincent Baldwin
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 28, 2019
Vincent Baldwin
Contributor
Level 1:
Answers
Questions
0
Helped
1092
Points
Behringer MS40 *** Bypass the short -
Using the RCA connectors for input? The left (or) right could have went out somehow.(That is for someone that wants to open the thing to find out WHY) But use a double RCA to- mini Jack (male) connector so you can use your stereo ~ Line one input.
2 Related Answers
Anonymous
  • 23 Answers
  • Posted on May 04, 2011
SOURCE: Hello, I just bought a BEHRINGER
Have you connected the Left speaker to the right speaker using the supplied cable? If not, connect the cable to the socket on the back of the right speaker labelled "to left speaker" and on the left speaker, to the socket labelled "from right speaker"
If this still doesn't solve the problem, try swapping the input cables (put the white plug in the red socket and vice versa) to see if this makes the left speaker produce sound, if it does, check the connection at the source to check the plug(s) are in all the way. If there is still no sound in the left speaker, unplug everything and do the following:
connect the left and right speakers with the supplied phono lead (Probably black) between sockets labelled "to left speaker" and "from right speaker"
then connect the source to any of the inputs on the back of the right speaker (ensure if using the red and white phono inputs that both are connected)
finally plug in power source.
Hope this helps
Anonymous
  • 5 Answers
  • Posted on Dec 27, 2011
SOURCE: my behringer ms40 right speaker magnet is broken
get a new speaker Beringer uses janson speakers and are available on the net
Top Music Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Music Expert? Answer questions, earn points and help others
