magicjack.com Logo
A
Anonymous Posted on Apr 20, 2014
Script error - magicjack.com
stephen Adams
Level 3:
  • magicjack.com Master 2,219 Answers
  • Posted on Feb 04, 2015
stephen Adams
Level 3:
Answers
2219
Questions
0
Helped
366354
Points
22262
On your softphone, please do the following:
1.Click "Menu" on the top right-hand corner
2.Click "Advanced Users"
3.Click "Restart"
If your magicJack is plugged into your modem or router, unplug it from the power source, wait 30 seconds, and plug it back in.
If that does not work:
<Requires some technical understanding. Explanation below. >
Please open port 49152-65535 UDP on ALL firewalls and your router, if you have one. (Router ports can be opened via the web application applicable to your router).
Restart magicJack again by following the steps above.
How to access Web Application for router
1.Start > Run > Type in cmd > Press ENTER
2.A command prompt will open
3.Type ipconfig > press ENTER
4.Make note / write down name of the default gateway and IP address
5.Open your Internet Browser
6.Type in the default gateway IP (Example: 192.168.1.1)
7.Type in Username and Password
8.Find "Port Forwarding" and Forward Port 49152-65535 UDP for the IP address you located earlier.
Script: chrome://wrc/content/common/libs/jquery-1.5.2.js:3589
Script errors are common. The best thing to do is to go to the internet options and deselect the entry that says "warn me of script errors".
Though the errors will still be there you won't get the notice!
1helpful
2answers
Keep getting a box popping up talking about script errors. how do we stop that?
If you use Internet Explorer as your Web browser, chances are you have experienced, or will experience, popup script errors. Typically, a dialog box may appear stating "A Runtime Error has occurred. Do you wish to Debug?" or "Internet Explorer Script Error. An error has occurred in the script on line 1. Do you wish to continue running scripts on this page?" These errors can be distracting and interfere with your Web browsing experience. If you would like to stop receiving these error messages, you must modify your IE settings.
Open IE, select "Tools" and ten choose "Internet Options." The Internet Options dialog box will open. Click on the "Advanced" tab, scroll to the "Browsing" section and then select the "Disable Script Debugging" box.
Clear the "Display a notification about every script error" box under the same section if it has been selected. Click "Apply" and then choose "OK" to modify your IE settings. You will receive no more IE script error notifications. Hope this helps.
Script error while going to yahoo chat room
First try to enable scripting through Internet Explorer
Go to Internet Explorer,
Click "Tools"
Click "Internet Options."
Click "Security" tab.
Click "Custom Level" button.
Scroll down to "Script ActiveX.controls marked safe for scripting"- enable
Scroll down to "Scripting - Active scripting" - enable
Scroll down to "Scripting of Java applets" - enable
Click OK
Click OK
I hope it will work.
Please let me know.
Thanks.
2helpful
When i enter the chat room i got the notice... a error has occured in the script on this page line:7 char:2888 error:permision denied code:o url: http://yui.yahooapis.com/2.4.1/build/con... min.js
You may not have Internet Explorer as your default browser but it is coded with Yahoo Messenger
For this reason you must keep it up to date and the support software as well. You do not have to set it as default but you need to keep itclean.
Flashplayer FOR IE
Shockwaveplayer FOR IE
Java
Check out the Yahoo Messenger Scripting Help page
1) Visit this page and select your product version (Messenger version) using the drop box
http://help.yahoo.com/kb/index?page=prod...
2) Type into the search bar: ......... script error...........and hit 'Search'
3) Browse the section for your problem and your OS and click on the link
To enable scripting:Internet Explorer8
Click "Tools"
Click OK
Click OK
Restart IE Source(s):
Script problem in Explorer 8
What should you do about Internet Explorer script errors?
In most cases, you can ignore them. Script error messages are displayed by Internet Explorer when there is a problem with the JavaScript or VBScript code on the website you are viewing. Occasionally a script error can be caused by an error in downloading a webpage, but more often it is an error in the webpage itself.
To be sure it isn't an error in downloading, click the Refresh button, or press F5.
getcontent.aspx?assetid=6d65df30-1154-45a1-9855-1232c6b27475&documentset=en-us&prod=win700&market=usInternet Explorer refresh button
If the error persists, and you are not a developer testing a website, you should click No to ignore the error.
To avoid script errors in the future, you can turn off script debugging and notifications in Internet Explorer. Script error debugging and notifications are turned off by default. If they have been turned on, follow these steps to turn them off again.
  1. Click the Tools button, and then click Internet Options.
2. Click the Advanced tab, select the Disable script debugging (Internet Explorer) and Disable script debugging (Other) check boxes.
3. Clear the Display a notification about every script error check box, and then click OK.
2helpful
2answers
Internet Explorer Script Issue ? When I mov from Homepage to profile n IE Script error dialogue box opens
If you want to disable Internet Explorer's displaying windows when there is a script error on a page,
  1. Start Internet Explorer
  2. Go to Tools / Internet Options
  3. Click on the Advanced tab
  4. Under the Browsing section, check Disable script debugging and uncheck Display notification about every script error
    Source: http://www.onecomputerguy.com/ie_tips.htm#script_debug
2answers
Internet Explorer Script error
You may have scripting disabled in your Internet Explorer.
Click "Tools"
Click OK
Click OK
Restart IE
Still not working ? Update software
use the links on this page to help update software.
http://help.yahoo.com/l/us/yahoo/messenger/messenger10/notices/mstabuguqscripterror.html
After updating check you do not have old versions of Flashplayer, Shockwaveplayer and Java running alongside the latest - this can cause conflicts
Start / control panel / programs
delete any old versions
1helpful
2answers
How ca i remove the script error in yahoo messenger
Click "Tools"
Click OK
Click OK
Restart Internet Explorer
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/notices/mstabuguqscripterror.html
Outlook express script errors
Common script errors messages can be eliminated by Clicking-Control panel - Internet Options - Advanced tab.
Check "Disable script debugging"
Uncheck "Display a notification about every script error"
If no joy then
Microsoft's Scripting download
Get the latest. Two download versions are available for Windows Script 5.6.
The first version requires Windows 2000; the second version requires
Microsoft Windows 98, Millenium Edition (Me), or NT 4.0. Please choose the
download appropriate for your operating system.
http://msdn.microsoft.com/downloads/defa...
=/msdn-files/028/001/175/topic.xml
Also, make sure you should not have Bad HTML bad coding as man people faced the same issue with outlook express.
Thanks for using "Fixya".
Top magicjack.com Computers & Internet Experts
Steve Pack
Steve Pack
Not Me
Not Me
stephen Adams
Are you a magicjack.com Computer and Internet Expert? Answer questions, earn points and help others
