Weller HEW100P - Heater Assembly for W100P Soldering Iron Logo
A
Anonymous Posted on Apr 19, 2014
Cold iron My new Weller 100P soldering iron stopped working after only a few days. I changed the tip, cleanedthe tip, but still on heat. Any suggestions?
Your Consultant
Level 3:
Master:
  • Master 825 Answers
  • Posted on Nov 05, 2014
Your Consultant
Master
Level 3:
Master:
Answers
825
Questions
Helped
213154
Points
1873
If under warranty - return it
4 Related Answers
MalKontent68
Stan
  • 748 Answers
  • Posted on Jul 15, 2010
SOURCE: my Weller PSI100K Portasol soldering gun will not
It is supposed to produce heat there, it's the place where catalytic combustion takes place. If the tip doesn't heat up enough, it means that either the tip is not screwed properly into the housing, or there's not enough gas pressure. The catalytic mesh should be orange in color when heated properly.
Too low gas pressure may be a result of many things, like a malfunctioning valve (regulator and/or on/off),or clogging of the ceramic pressure reductor due to poor quality gas used, with high heavy fraction content.
Anonymous
  • 33 Answers
  • Posted on Aug 30, 2010
SOURCE: I have a Weller 1002B soldering station. Haven't
Hi, I'm not sure the tip is defective. Check that the tip is screwed in tight. If it is not good and tight the tip will not get a good heat transfer from the solder wand. Hope this helps. If the wand will heat then the tip should.
Norman Worley
  • 1273 Answers
  • Posted on Dec 10, 2010
SOURCE: Hi, I have a
See: http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=weller+WM17D+soldering+tips&x=15&y=19
Also Radio shack may have the tip at a larger price, but you don't have to pay shipping
Anonymous
  • 185 Answers
  • Posted on Jan 12, 2011
SOURCE: The tip of my weller
This happens quite frequently. On the tip there are two nuts that hold the tip to the gun. Tighten them a bit. The tip is made of copper and as this heats, it causes the connection where the nuts are to become a higher resistance and thus lower heat. When you tighten them, it "cuts" through the copper oxidation (caused by the heat) and lowers the resistance, hence more heat.
Top Weller Welding Tools Experts
ADMIN Andrew
ADMIN Andrew
Are you a Weller Welding Tool Expert? Answer questions, earn points and help others
