A
Anonymous Posted on Apr 15, 2014
E0010 iR 6570 - Canon IMAGERUNNER 6570 Copier
srinu
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Jun 11, 2014
 srinu
Contributor
Level 1:
New Friend:
Answers
21
Questions
5
Helped
8945
Points
43
That was feeding motor problem, in the motor chek the fuse or replace the motor
1 Related Answer
sodeep
Sudeep Chatterjee
  • 3269 Answers
  • Posted on May 07, 2012
SOURCE: ir 6570 copy light
When you were replacing the drum did you tuch the drum surface?Best would be that you take some toner on piece of cloth, and polish the drum, while turning it in good direction, that the cleaning blade can clean it.After you must let it copy about 50 copies.
You can try to replace the whole drum unit cexv14, or clean the laser unit.
Also could it be that the toner unit, or toner cleaning blade are not properly distibutes the toner accross the developing/toner cylinder
E821 error code in canon IR 6570 ?
error code relative to the clogging of toner inside the waste toner auger tube. this will require a technician.
2helpful
Ihave ir 6570 it shows e-00225-001 error
check the mirror fitting on the scanner.
IR 6570 is showing error 20
it was tonner assembly sensor problem ,change the sensor and check it.
Cannon ir-6570 have occured e 025-001
Error has to do with the toner bottle not turning. Check to see if bottle is bound up. Remove and reinstall.
57helpful
3answers
IR 6570 Sheets at the press completely blake
Make sure all your High voltage units are plugged in.
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
