Computers & Internet Logo
Posted on Jun 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need driver Need Vista drive
  • Anonymous May 11, 2010
    What type of Vista driver?
Anonymous
Level 2:
  • Expert 77 Answers
  • Posted on Jul 18, 2009
Anonymous
Expert
Level 2:
Answers
77
Questions
0
Helped
78408
Points
228
  • www.drivershq.com
  • Vista Drivers and XP Drivers at your finger tips when you use Driver Detective software and service. Drivers HeadQuarters is the first and only driver ...you can get it frm there
Need driver for SmartDisk FireLite 40 GB Hard Drive
I found drivers at this URL: http://www.xpdrivers.com/usb/smartdisk/_3_2585.cfm
You should go there and be able to find what you need for the 64-bit Vista OS.
Good luck,
-a.
Just need a samsung sp1604n driver
Any drivers needed will be on the samsung website, but unless you are using an old motherboard and windows xp (may need drivers loaded off a floppy drive) no drivers are needed.
If you are using Vista, your problem may lie in your motherboards bios, it may need an update
I need driver for Windows Vista
Hi i cannot find the driver either , but what you can try is Download XP drivers for it , then right click and run in compatibility Mode for XP , and it should install
Same problem with my MPF82E
You see floppy drives are pretty old technology compared to the Vista environment which is the latest. Your floppy external drive will most likely run better in the Windows XP environment along with the necessary drivers on device manager under control panel...and those drivers you can also download. Am sure it will work better with windows 98 or XP.
Thanks & Kind Regards
1helpful
3answers
Free CQ40 webcam driver for vista version
sir i want all drivers hp compaq presario Cq40 drivers give me
Audio drive with vista
Since this model was not made to run VIsta but Xp the Xp drivers,of course, will not work with Vista. Download the manual . Find out which Audio chipset it has. Go to the audio chipset manufactors websiteand download the VISTA driver for that chips set, if one was ever written.
Can't install vista
You need to find the drivers for the controller card.
Put the drivers onto a floppy drive. When the software asks for the drivers, use those drivers to let the OS know where to look for the hard drives.
I'm not sure if vista can load drivers off of a USB thumb drive. I havn't actually tried it yet.
Check Maxtor for the drivers you need.
2answers
Driver for vista
Canon says the driver is pre-installed in Vista -did you even go to their website to investigate -it's right there
3answers
Need vista driver for FD-05PUB teac usb floppy drive
You should have (if bought new) had a mini disc in with the drive. If not try the manufacturers site and download it. It's also possible by doing the add/remove hardware and pointing towards Microsoft for the driver it will install for you. Hope this helps...Tango.
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
