True 26 cu. ft. Commercial Freezer GDIM-26 Logo
A
Anonymous Posted on Apr 03, 2014
Can I bypass defrost timer
It is stuck in DS2 can I bypass the defrost timer
akersken
Level 2:
Novelist:
Scholar:
  • Expert 187 Answers
  • Posted on Nov 04, 2014
akersken
Expert
Level 2:
Novelist:
Scholar:
Answers
187
Questions
Helped
58381
Points
212
Its not a good idea. If you cross up the wiring you may cook the thing.
Defrost timer stuck in ds2
needs to be replaced
Defrost timer stuck in DS2 what can I do
I do not know this unit but I would assume the defrost timer has failed. Check if it is in warranty, if so make a warranty claim, if not you would either replace it or have somebody do that for you.
1helpful
Frigidaire freezer runs a lot. Located in garage. In summer runs almost non-stop. Currently outside temps are below 0 deg F and freezer still cyles frequently. Have replace the freezer tstat. Defrost...
Yup, these timers have a tiny clock motor that can get lint on them, causing motor failure, should be simple replacement. Refrigerators in cold garages run more to regulate their temperature below 45 degrees.
Jan 29, 2014 • Freezers
1helpful
Coldspot model: 106 725540 freezes sometimes
You can by pass it but I wouldn't. You may need to replace the t'stat on this. This controls pretty much everything. Depending on your model, the defrost cycle can be adjusted to shorter cycles. Bypassing it would eventually lead to ice build up and a real mess to follow .
Feb 04, 2013 • Freezers
HOW TO BYPASS
If the refrigerator is not icing up it could be the defrost thermostat making the defrost cycle initiate every time the defrost timer makes defrost available. I do not recommend by-passing the defrost cycle, have the switch checked and replaced if needed.
Unit will not go into defrost.
There is a good chance, if the defrost timer is mechanical, that you can rotate (nudge) the timer to see if it get's going.
Most commercial refrigeration does not use a defrost thermostat, and a lot of it does not use a heater (they use a hot gas bypass valve and pump hot gas through the evaporator, rather than through the condensor.).
Let me know if you need further help.
2answers
Frigidaire Upright freezer FFU20FC4AW2
Sounds like the timer could be getting stuck and not releasing the defrost cycle. If you have to do it again, you should have the timer checked, or just replace it.
1helpful
Frigidaire Freezer Model FFU20F9FW1 defrost problems
you say when you advance the defrost timer , id assume turn it ever so slightly the machine kicks on ad begins to freeze again?? then prior to advancing timer i would expect the unit to be totally dead(stuck in defrost mode).no fans,compressor or anything. that suonds like a bad timer or chck the wires going into the timer
Mar 05, 2008 • Freezers
Top True Freezers Experts
ADMIN Andrew
ADMIN Andrew
Simon Atkinson
Simon Atkinson
MUKHTAR
MUKHTAR
Level 1 Expert
Are you a True Freezer Expert? Answer questions, earn points and help others
