Sharp Aquos LC-C3234U 32 in. LCD TV Logo
Frumbie Hinz Posted on Apr 04, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to replace a ccfl backlight - Sharp Aquos LC-C3234U 32 in. LCD TV
Mike M
Level 3:
  • Sharp Master 3,349 Answers
  • Posted on Apr 04, 2014
 Mike M
Sharp Master
Level 3:
Answers
3349
Questions
0
Helped
704741
Points
16707
Screen is black
This website sells both replacement CCFL backlights and upgrate LED replacement backlights.
update ccfl lcd to led lcd led strip led backlight led kit led backlight...
CCFL backlight flickering or going out when adjusting screen
Yes you can replace the CCFL lamp.
To replace the CCFL lamp requires removing the front screen bezel, removing the LCD screen from the frame and the reflector which is located on the bottom edge of the LCD screen. The CCFL lamp is located inside the reflector and the electrical wires on the ends of the CCFL lamp are connected to the inverter board.
Replacement parts are available from these WEB sites. www.lcdparts.net http://www.lcdparts.net/adword/ledkit.aspx?gclid=COzzndCVvbYCFQFipQodrH0AJw http://www.yallstore.com
Toshiba satellite M305 S4907 comes on but monitor is blacked out can barley see
http://www.screentekinc.com/Toshiba__Satellite__M305-series-laptops-lcd-screens.shtml
The Toshiba Satellite M305-S4907 Notebook PC, uses a single CCFL for a Backlight.
Primer before we go on;
An LCD screen cannot produce light. It needs an additional light source,
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/
Click on the monitor image.
The additional light source is a Backlight.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
(Light Emitting Diode)
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height.
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
View the last 8 photos.
A screen Inverter is used on laptops that use CCFL for Backlighting.
A screen Inverter converts the power (Electricity), from the laptop, for the LCD screen, and Backlight.
Laptops that use a series of LED's for backlighting, do Not use a screen Inverter.
90 PERCENT OF THE TIME the fault can be attributed to a bad screen Inverter.
http://www.sparepartswarehouse.com/Toshiba,Satellite,M305-S4907,PSMD8U-02R015B,Laptop,Inverters.aspx
The plastic thin frame in front of the LCD screen, is the Display Bezel. (Toshiba = LCD Bezel)
The screen Inverter is located behind the Display Bezel, and mounted at the bottom of the LCD screen.
(LCD Screen Frame, actually)
Easy to get to; easy to replace.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-M305/remove-screen-inverter-video-cable-1.htm
How to test a screen Inverter? Requires a Sensitive multimeter.
Read fairly expensive,
http://www.fonerbooks.com/test.htm
Because of this; and the low cost, plus ease of replacing; most home users just opt to replace it.
Know this;
Fluorescent lamps have MERCURY inside. HIGHLY poisonous.
Now couple that with the long thin makeup of the CCFL, and how easy it is to break it.
This is why if the screen Inverter is found to NOT be the problem; I would suggest replacing the LCD screen itself; instead of trying to replace the CCFL, and cause possible Mercury poisoning.
For additional questions please post in a Comment.
Regards,
joecoolvette
I need a replacement screen and i'm not sure which cffl/backlight to order
Here are the eBay search results for your exact system model -
http://www.ebay.com/sch/i.html?_trksid=p5197.m570.l1313&_nkw=Toshiba+Satellite+L355D-S7809+screen&_sacat=0
Right now, my laptop screen is black. I can hit Fn
I'd guess that it's the CCFL (backlight bulb) going bad. What points me in this direction is that you mention that the backlight (when you're able to get it to turn on) isn't producing bright white light (and pink is one of the colors that normal fluorescent tubes produce when they're failing). You're in luck because CCFL backlighting isn't the most difficult thing in the world to replace (if you can handle delicate electronics) and you may just be able to hack together some LED backlighting for yourself while you're at it. There are a few reasons that LED backlighting is better than CCFL but the most important is that LEDs last pretty much forever.
There are a number of video tutorials on YouTube about replacing the backlight of an LCD display and a few of them detail the installation of bright-white LEDs in place of CCFL backlights. If soldering and math aren't your strong suits a drop-in replacement for the CCFL tubes should be fairly easy to find online...
Power supply to the screen backlight keeps going out
You may have a faulty inverter or defective CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Backlight very low making screen dark
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
www.ladparts.net
Lcd screen d600 backlight turns off after 1 second
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
1helpful
Led backlight on display for m1330 xps dell
This model laptop uses a CCFL lamp for the backlight, it does not use LEDs for backlighting.
The CCFL lamp is attached to an inverter which supplies high voltage to this lamp.
For details on how to install and or replace CCFL lamps go to
www.lcdparts.net for information and parts.
I assume you are not replacing the whole LCD screen.
2helpful
Dim display ... no backlight
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
