NEC NP-M311X XGA 1024 x 768 LCD Projector Logo
A
Anonymous Posted on Sep 28, 2017
Network windows 7
Hooked up the projector to the network. This can be used through the software provided and works fine. But we want to be able to use it with Windows 7 network projector tool, so that we dont have to install the software on any other machine when there is a meeting in the conference room (different laptops/desktops used). So using the software isn't feasible
5 Related Answers
Anonymous
  • 3587 Answers
  • Posted on Mar 20, 2008
SOURCE: Syncing my MobilePro 790 with my computer
yes...quite an issue, eh? what is the actual model and make of that device?
egadgetguy
Ken Williams
  • 263 Answers
  • Posted on Jan 01, 2009
SOURCE: Can the same Windows cd be installed on a laptop as on a desktop?
The answer is two fold.
1. The system can be installed on any number of computers using the same install disk.
2. Microsoft frowns on this because using it on more than one PC box is considered copyright infringement.
Also, some PCs come with install disk that contain only drivers for the PC hardware it came with. It is not a good idea to use this CD on another PC.
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Mar 25, 2010
SOURCE: I want to use a NEC Multisync 1700V monitor as an
The only I can think of is the resolution setting that your T400 is putting out that your NEC does not like andcannot display, look at the T42 resolution when the NEC is hooked up to it and try to set it to be the same in the T400.
Anonymous
  • 1082 Answers
  • Posted on Sep 11, 2010
SOURCE: i reformat my desktop using
Using the driver disk that came with your computer, install the missing drivers.
If you don't have that disk, you'll have to download the drivers. Using a program like Belarc, determine what components are installed, search using google for Win7 drivers. Not a very elegant solution but it works.
http://www.driverstart.com/start705662.html might work.
Anonymous
  • 76 Answers
  • Posted on Aug 11, 2011
SOURCE: connecting projector to laptop works
Your laptop should have a FN key and an 'F' key (The image on the key looks like two monitors side by side or it will say LCD/CRT) which you need press simultaneously to allow the laptop to send the signal out through the VGA port. Usually I have to repeat the process three times to allow the image to be presented on both the laptop screen and the projector. If this still doesn't work, go into desktop properties, advanced and unclick the square saying 'extend to..............' (sorry I can't remember the rest of the extend bit as I am in front of my PC not laptop and the settings are different. You should find it though.
Good luck
Top NEC Office Equipment & Supplies Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
