Ryobi ert241200, collet won't lock in bits with quarter inch shanks
SOURCE: Have lost collet and collet nut for Ryobi601.Need
Part # 24 here is the collet nut.
Here are a couple of adapters.
You can set up an account and order them directly from eReplacement Parts.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: Collet on Freud router won't release bit
a new collet won't hurt, but you may try sanding down the inside of your existing collet with 120 - 180 grit sandpaper. also, buff down the router bits
any condensation or moisture that may have gotten on these items can cause almost invisible oxidation that you can remove easily by sanding. DO NOT USE WD40!!!
Testimonial: "Tks! Will try sandpaper inside collet. Not sure buffing bits will help, since likelihood of ALL of them having a surface problem is pretty low."
SOURCE: ive got a kenzo router and the router bits do not
Your router bits must have a 6mm shaft, whereas your router with the collet closes down on a 1/4" or 6.4mm shaft. You will need to get a metric collet for your router spindle, or get a new set of 1/4" bits
SOURCE: I have a brand new Ryobi router model ERT241200.
Do you have the collet upside down? It should fit in nicely and the lock nut fit over the top, no problem, If it doesn't, something is wrong. They only make 2 sizes of collets for router bits, 1/4 and 1/2 , if they get their parts from somebody who makes just collets, you could have easily gotten a different size in there. See if a router bit will fit the hole, then go to the store where you bought the router and ask them to try it in your router and see if it fits, they might have collets on the shelf. Check it out.
Testimonial: "thanks - I will do that"
