Error 1305 E:/setup/ProgramFiles/Print master P:latinumks.1/Content/PM17Getty.1Dt Verify the Program exists and that you can access it. Shouldn't it already be on the disc?
SOURCE: Print Master 10
PrintMaster 10 is designed to work with Microsoft Windows 95/98/NT/2000, so in order to use it with Vista or XP, you should open it using Compatibility mode--> Right click on the program icon--> properties-->Compatibility--> select Windows 95/98/NT/2000
SOURCE: error message 1305
Microsoft has error 1305 as an "error reading from file." Check out http://support.microsoft.com/kb/248263 And try there troubleshooting, it could be that the disc is scratched or dirty, the drive could be bad, or it may be incomp[atable with the current operating system. The above link is your best first attempt at solving the problem.
good luck, hope this helps.
SOURCE: Is it possible to install / import old PrintMaster 7.0 Art Discs?
When you put the Program install disk in follow the prompt but instead of selecting the "Typical" instalation select "Custom". This way the install will instruct you to select the two or one or none Art cd.s. I assume your copy of Printmast 17 Platinum has all 4 cd's?.If not then you will only have installed about clip 950 art etc. instead of 19,000 plus when you install the Art disk 1&2.
The only drawback is that the two art disc's add another 1gb to the hard drive usage.
I hope this helps.
Brian Wright
SOURCE: Broderbund program CLICKART 950,000
Some programs do not install the full contents of the disk. Was there an option for full installation or part installation? Try running the program with the disc in your pc-the the art gallery clips may well be on the cd and not copied onto your pc even though the software program is.
SOURCE: I get an error 1305
Problem
Error 1305 or 1304
Solution
The Print Shop® 23
Error 1305...
When attempting to install The Print Shop® 23, an error that includes the message "Error 1305..." or "Error 1304..." appears. A conflict during the installation may cause this issue. Completing a clean installation of the program will help to prevent conflicts that can occur. The remainder of this note describes the procedure.
Complete the steps below to reduce conflicts during the installation.
Clean the CD or DVD
NOTE: If the error message reappears, I don't know an another massage.
I hope it works for you
