Canon imageRUNNER 2545i AllInOne Laser Printer Logo
Ekera Teia Posted on Mar 18, 2014
Error code E0000
Before the error is E000002.After I replace new fixing unit then the new error E00000 is appear again.Any solution
5 Related Answers
Anonymous
  • 159 Answers
  • Posted on Mar 23, 2008
SOURCE: E00002-0000 error code
ont. Panel, press the following, one after the other, * (additional functions), 2, 8, * (additional functions). You are now in Service Mode. Touch the Function Tab, touch the Clear button, touch the ERR button, when it is highlighted, press the OK button at the botton of screen. Power Cylce unit. If it comes back up, may have been a fluke. However, if it comes back, check your Fixing Assy for jammed paper, or damage to the Fixing Film (Upper Roller). Replacing the Film is not hard. After you remove the Fixing Assy., its a couple cables and springs. Rather on the easy side for Film replacements. Remebmer, on these models, the Film is also the Heater and Upper Fixing Roller. The Film is most likely on the pricey side for new, believe you can find rebuilds. Just keep in mind that the Film is still a lil' bit cheaper then the whole assy., and 8 out 10 times, its the Film that fails in the asssy
Anonymous
  • 6 Answers
  • Posted on Dec 01, 2008
SOURCE: COPIER GIVES THIS ERROR E0000-840-0001
this err belongs to sensor problem.
chech thermostat sensor
Anonymous
  • 92 Answers
  • Posted on Sep 26, 2009
SOURCE: Cannon image runner 2200 error code E000002-0000,
E002/E000/E003/E261/E733 Error code: Due to AC line noise Error Code
Symptom E002/E000/E003/E261/E733: due to AC line noise. Description E002/E000/E003/E261/E733 occur due to AC line noise.
If the above error codes are frequently recorded in the error log, they might concern AC line noise. Cause When the machine tries to detect a Zero-cross signal of AC line, it will fail if a noise occurred around the zero-cross point. Since the fixing temperature is controlled based on the zero-cross signal, there is a possibility that the fixing temperature could not rise properly if a noise occurs several times. Field Remedy Replace the Switching Regulator PCB ***'y with a new one.
120V: FH3-2613
220V/240V: FH3-2614
The circuit has been modified to resist a noise. REMEDY Caution
 Press (* then 2 and 8 together then *)you are in service mode monitor:
To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
GOOD LUCK MATE ......KINDLY RATE ME !!!! THANKS.
Anonymous
  • Posted on Dec 21, 2009
SOURCE: CANON IR5000 ERROR CODE E000002-00000
NEED HELP WITH ERROR CODE E000246-0005
Anonymous
  • Posted on Jul 01, 2010
SOURCE: My Canon imagerunner 3300 displays an error code
plz help me at the problem E00051-000
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
