Gestetner DSm620d All-In-One Laser Printer Logo
B
Burretha Williams Posted on Mar 11, 2014
Code SC541 on machine - Gestetner DSm620d All-In-One Laser Printer
Michael-John
Level 1:
New Friend:
  • Contributor 49 Answers
  • Posted on May 09, 2014
Michael-John
Contributor
Level 1:
New Friend:
Answers
49
Questions
5
Helped
17329
Points
55
Replace the thermistors on the heating unit. There are 2, replace them both to avoid disappointment.
What does functional problem SC541-00 on a Savin copier 2035DPE
SC541 is a defective thermistor, clean or replace the two thermistors (Edge and Center) on your fusing unit. after replacing or cleaning reset the SP Code 1. On the operation panel, press Clear Mode ". 2. Use the number keys to enter 107. 3. Press and hold Clear/Stop # for three seconds. 4. On the touch-panel, press Copy SP. then turn off and on the machine
4helpful
Code sc541 Ricoh Aficio 350 copier
please follow the instruction and you will reset the copier:
press the follow keys in order:
1. press the yellow key[c] (clear)
2. press 1-0-7 on the number pad
3.press and hold it pressed the red key [c] (stop)
4.When on the screen will appear other menu different from the usual turn off the machine from the main switch (the red switch) and then turn it on after 5 seconds.
Please answer do this is helpful for we to know if is needed some more information.
5helpful
2answers
Gives code sc541 on Ricoh 1035
Clean the fuser thermistors.For reset enter in the service mode : press total clear (yellow)key-107-clear(red)key,touch SP mode,open the front door and turn OFF the power switch.Unplugged the machine,wait 10 sec.,plugged the cords,close the front door amd turn ON the power switch.
15helpful
Erro code SC541
Fuser error.
Fix problem (Fuse, lamp, or thermistor), then reset code by entering service mode and powering off/on machine
Getting SC541 code on our copy machine. what does that mean?
It must be a Ricoh copier,and the model doesn't matter. This code is a fuser warm-up error, and can only be reset in service mode by a technician after the problem is fixed.
1helpful
Error Code SC541
The Fuser Thermister is not working properly. The Fuser may need to be replaced or the two Thermisters need to be replaced on the fuser. This is what the code is calling for. A local Ricoh tech should have these parts. Hope this helped!
3helpful
2answers
Error SC541 ON NRG MP 1600L
First try entering into SP mode by pressing:
Clear button>1 0 7> and press and hold the Stop button for 3 secs. Then switch off and on the copier.
If SC 541 code is still there, check the following in the fuser unit:
  • Fusing thermistors defective or out of position
  • Thermostats open circuit
  • Power supply board defective
  • Loose connectors of Fuser unit.
Good luck and please rate me, thanks.
Solve my problum
I have a richo 2018d all in one copier machine it can be a error code SC541.
what is its solution ....
40helpful
4answers
About ricoh copier problem
sc541 is a fusing unit error code. Can you reset the code in service mode?
Top Gestetner Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
