Sharp Aquos LC-45GD4U 45 in. LCD HDTV Logo
Anthony Santoro Posted on Mar 07, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Green screen split screen
Level 3:
Top Expert:
  • Sharp Master 76,851 Answers
  • Posted on Mar 07, 2014
Sharp Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15380470
Points
237768
A bad symptom indeed. Contact the authorized service center. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Screen-shots to defective LCD screens are given. You can compare it to that of your TVs' and can make sure about the fault.
Hi.i can't split the screen on the ps3 when playing mine craft.to add a second player.my settings must be wrong somewhere?
To split the screen for a player 2 in Minecraft for the ps3 version, you must use a cable with the colors red, blue, and green, OR an HDMI cable to connect to your TV. If you are using another type of cable, you are out of luck.
Blu Ray showing "split screen/double
Did you check your settings on your tv and blu ray?
My screen color looks like the green and the red are split.
U hear grinding,squiling,motor noises,picture flicker black&white?This tv have a colors wheel.The problems u describing sound like the colors wheel it not functions correctly any more.
1helpful
Picture split
use one red the white and then try both green or blue with red and white
Colours split and vertical bowed green line at to and bottom of s
This is a convergence problem that can be either poor solder connections at the convergence ICs or defective ICs. If you can solder and feel comfortable working inside the set where there are potentially dangerous high voltages, update this and further details and instructions will be provided.
Thanks,
Dan
Red and green fuzzy waves across the screen
my screen just became distorted (red picturer to the upper right & green picture to the bottem left ? can you help me ? wuzuphippie55@yahoo
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Screen split into 2 colours - vertical split
I think it is degaussing problem if any thing is lying which has magnet please remove it. &then put of monitor for 15 minutes & then put on again.do not move when it is on. please let me if it gets ok good luck
Fuji Finepix split screen
If the picture taken from digicam are ok when viewed from a computer, the lcd viewer has a loose connection or defective already, if you can open your unit, try to disconnect and reconnect the lcd flexwire inside.
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
