Tablets & eReaders Logo
A
Anonymous Posted on Mar 04, 2014
500 internal server error what is this?
I keep getting this message
Why do i keep getting error when i register my kindle
If you encounter errors while registering your Kindle, there are several potential reasons. Let's troubleshoot:
Incorrect Password:
Double-check that you've entered the correct Amazon account password during registration. A simple typo can cause issues.
Time Settings:
Ensure that the time on your Kindle device matches the actual time of your location. Incorrect time settings can lead to registration problems.
Internet Connection:
Make sure your Kindle has access to the internet. A stable connection is essential for successful registration.
Software Updates:
Verify that your Kindle is running the latest software version. Outdated software can cause registration errors.
Visit the Kindle E-Reader Software Updates page to manually update your device if needed.
Internal Error:
If you encounter an "internal error" during registration, it means the device failed to handshake with Amazon servers when adding a new account.
Unfortunately, this issue may require further investigation or contacting Amazon support
I keep getting a message that my Google unfortunately has stopped working. Why?
That's google's server's issue, it happens every now and then. Just wait for a couple of days and it should be fixed.
They update a lot of stuff constantly, small errors like this isn't anything uncommon.
Get message "Can not connect safely to server"
First check to see if you're router is working as it should.
If it is contact your ISP server ie, comcast, verison.
If they say they can "see' your computer then the problem is with one of many of the privacy settings that are turned on on your software.
1helpful
Facebook on my playbook keeps saying the server is having technical difficulties error 500
From my own personal research and stuff I have read apparently adobe quit updating mobile android versions of adobe flash. I know kindle 1st Gen are also saying they are up to date yet there is newer pages that are not supported by these devices. So you may just not able to play what does not work anymore. Also may find soon other flash related stuff does not work as content providers start programming for newer versions of flash.. Not much as consumers we can do. But our devices are being forced into non compatability
How do reconncet to my server
Which error message? It probably a windows security setting issue. I have problems connecting to my DLNA server if I do so and a network share rather then as a media server for the same reason.
Irulu tablet support
Are you WiFi connected?
Error connecting to server
Error messages can mean several things. You may have lost internet connection for a short period or your tablet may be having problems with downloading. This is a common problem that happens to devices if they aren't working properly with internet or you could have interferance. Try down loading later at night, late late and see if it just happens to work.
We keep getting an error message that says error retrieving information from server RPC:S-3
We had the same problem with this exact tablet: fortunately, I found a video that showed how to correct this error - - cleardot.gif
http://www.youtube.com/watch?v=uv8d-nl04qI
Basically, you enter Settings;
Delete your Google account information;
Enter Apps, go to All Apps, and delete data in the following THREE places:
Download Manager
Google Play Store
Google System Services
Then, you re-enter your Google account information.
It worked for us, I hope it works for you, too.
1helpful
Cannot load into Gmail
Check your wifi and see if it's well connected or not. I think this is the main problem. Good luck.
Android 4.0 Tablet PC
Top Kobo Tablets & eReaders Experts
ADMIN Andrew
ADMIN Andrew
Les Davis
Les Davis
Are you a Kobo Tablet and eReader Expert? Answer questions, earn points and help others
