Refrigerators Logo
Dani Nemec Micsan Posted on Mar 03, 2014
Ge gss25pgmf The side by side refrigerator water dispenser drips water (ice make is fine). Noticed some time back that there was also less water pressure. Changed the water filter, and it fixed the pressure somewhat. I'm thinking I need to replace the dual inlet water valve at the back of the fridge?
Ashwin Patil
Level 1:
New Friend:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Mar 03, 2014
Ashwin Patil
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
15
Questions
0
Helped
1888
Points
25
Before replacing water valve open open back panel disconnected water line of water dispensser and tell some 1 to press water actuator on dispensor and check water pressure from it. If its slow then it can be valve or it can be filter housing. Repalce both if confuse.
5 Related Answers
Anonymous
  • 58 Answers
  • Posted on Oct 31, 2007
SOURCE: Kenmore Refrig with Filters water and ice dispenser- water is dripping when not in use, no flow when activated
valve needs to be replaced. it is located in the back, just follow the water line to it. to shut off water there is eaither a shutt off behind ref or in the basement. again try to fallow the water line
Anonymous
  • Posted on Nov 17, 2008
SOURCE: GE Profile side by side fridge - water dispenser doesn't work
More than likely, your water line is freezing up in the door. You can remove all of the ice cubes and lower the freezer temp to about 3. Leave the freezer door open for about 5 minutes or so and if this does not work, leave the door open a little longer. Also, disconnect the water line at the base of the freezer door, near the floor, and press the dispenser lever. If you have water there, you most likely have a frozen line in the door. Changing the water filter often will help but it is not the answer and is can get quite expensive. By the way, Make sure to hold the dispenser lever forward for at least a couple of minutes each time you test for water flow. If you do not get water at the connector at the base of the door after you have disconnected the line, you have a problem with the valve in the back of the refrigerator.
Anonymous
  • 74 Answers
  • Posted on Feb 26, 2009
SOURCE: ice maker and now water dispenser does not work
Do you get water to the connector at the bottom of the freezer door ? if you do then the water pipe in the door is probably frozen - read new door ! if not then check thw electrical connector at the bottom of the freezer door as they have a habit of corroding.
Anonymous
  • Posted on Mar 07, 2009
SOURCE: Water Dispenser Drips
Had the same problem after replacing over seven water valves and installing a water regulator in the water line to the refrigerator with no help. Had to reduce the water pressure to about 27 pounds the reduce most of the drips. It drips an amount about the size of a quarter and when the water gets the coldest it stops the drip, but there is always a droplet at the end of the water disperser tube.
The problem is with water stored in the refrigerator side of the box. Water come in and does not leak. After the water gets colder it expands and oozes drips from the water dispenser. It is worse with the roll of tubing behind the crisper drawer on the bottom, because there is no room for expansion in the tubing. We replaced the tubing with and older style tank and it helped some, but not completely. The solution is 1. Try to buy a refrigerator with a tank instead of the roll of tubing in the bottom of the refrigerator side. 2. Don't use the water dispenser. 3. Reroute the tubing directly to the water dispenser and bypass going into the refrigerator, the water will not be as cold. 4. Avoid those built by Whirlpool.
Anonymous
  • Posted on Jul 09, 2010
SOURCE: water leaking at filter
If this is a Pure source 2 filter in the upper right hand side of fridge, Purchase an Electrolux filter bypass, P/N 241944302. This is a empty cartridge that lets water flow without water drip when filter is clogged. Fridgidaire/Electrolux made no bypass in these filters, so when clogged they leak. Plus they NEVER last more than about 30/60 days. If you use the bypass, you will need a separate filter elsewhere such as in water line under sink or behind fridge. Call me at 816-560-8545 if you need more info.
Top General Refrigerators Experts
vince
Paul Bade
Arnie Burke
Arnie Burke
Are you a General Refrigerator Expert? Answer questions, earn points and help others
