It's a fail safe to save other board inside your set from stray voltage. The error LED code says your PSB Power Supply board has some blown capacitors on it. First try a hard reset by unplugging the set for 4-6 hours. If that doesn't work you need to remove the pack panel and look for the Blown caps on the PSB. Caps should be completely flat (X) top view. Not puffed or bulged. Radio shack harbor freight for a soldering kit with flux and some new thru-hole caps about 2v above your current cap rating. Get them too big and you risk them exploding and they are hard to seat.
SOURCE: shut off blinks 11 times
I have recently solved the same problem with my panasonic that was just 2years 2months old. I took off the back of the tv and brush off the dust as there was too much dust clogging the vents and fans at the back. The tv is now as good as new. Hope your luck is as good as mine. by the way i was having 11 blinks as well.
SOURCE: Panasonic plasma 50PZ85 power led blink 10 times
Either a bad power supply or a bad processor board.
A Good Service Shop should know what the 10 blinks are indicating.
May be a repair cost between $200 and 400 dollars.
Be prepared -
Blessings,
A/V Media Guy
SOURCE: Heard a popping sound unit
10 blinks on this set is not a power supply fault but rather an A-board fault(Main A/V board). Hence replacing power supply would not do the trick. I suggest you return the board and get an A-board for +50$ and I am confident that it will resolve your problem.
Sai.
SOURCE: TH46PZ85U comes on shuts off
Symptom of internal fault. Refer your user manual's troubleshooting section and see if they have mentioned anything about this LED blinking. If not, contact the Panasonic technical support.
SOURCE: RED LED BLINKS CODES
For more details, just type in the site name "Electro-help" to
your search engines' search box [not in the address bar of your browser],
and click search. It is an electronic
equipments service help site. All details you want
are there. Note the position of
hyphen in between words in site name, when you type it in. The site will appear as it is in
web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts.
You can get all details. You can locate it
either at the bottom part of first search page, or at the top of second page.
Detailed descriptions are there to help you.
Sometimes, clicking on advertisements by the side and
bottom of each post might help you to get details about the availability of
spare parts; price etc:-
