I have an Acer Aspire one KAV60 and it works for a little while and then i get white and grey lines going thru the screen. i can adjust the monitor to the full extension and it fixes the problem, but how can i fix it so that it stops completely?
SOURCE: My acer Aspire 9300 monitor is white with gray
check your LCD connectors. if full of vertical lines at your Screen that VGA Memory. trust me!
SOURCE: Acer Aspire One, Screen turns strip-y grey/white
hi there, my sisters dell laptop does the same thing. My best guess is that a hard knock on the graphics card and knocked a few pins out of it. This is something that a average person can not do. My suggestion is to bring it to a computer shop and tell them that you think it's the monitor connections.
SOURCE: Grandson dropped his Acer Aspire
My suggestion is to replace the LCD with new one. Let the certified technician to work on that. You cannot perform the DIY on that. Its too complicated.
SOURCE: screen particially blacking out with vertical
Tryconnecting an external monitor to the laptop. You may have to select the videooutput to display on the external monitor by holding down the blue key and pressing the blue CRT/LCD (located on one of the keys, likeF8,F9, etc..). If the problem occurs on the external monitor with the batteryor AC power, then you have a problem with either the video card or motherboardin the laptop. If the problem does not happen using the external monitor thenyou laptop's LCD display is going bad.
