Washing Machines Logo
A
Anonymous Posted on Feb 18, 2014
Error code 1
Washer/dryer returns to spin cycle as soon as the machine is switchd on. when you move the dial to wash cycle it falshes uop error 1
Dado
Level 3:
Master:
  • Ariston Tech... Master 511 Answers
  • Posted on Oct 06, 2015
Dado
Level 3:
Master:
Answers
511
Questions
0
Helped
493796
Points
1313
F01: Triac Short circuit
Overhaul CNE
Replace Card
Dado
5 Related Answers
Anonymous
  • 18 Answers
  • Posted on Jul 11, 2007
SOURCE: MACHINE DOESN'T CYCLE OUT OF RINSE
Does it spin if you move the timer manually? ist it being used on a delicate cycle@? if so it will stop in the last rinse water
Anonymous
  • 417 Answers
  • Posted on Feb 05, 2008
SOURCE: Ariston combo ( washer + dryer)
Hi there the controller board is faulty replace main controller board.
Thanks J
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jan 13, 2009
SOURCE: Ariston Front Loading Washing Machine error code F07
Error code F07 is indicating that the heater relay is stuck for one reason or another.
This could be a board problem, as this where the relay is located.
However, it would be worth checking that the heater is o/k before you do anything else., as this possibly could cause the relay to malfunction.
Plz rate my solution.
Thanks.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jul 24, 2009
SOURCE: Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Anonymous
  • 41 Answers
  • Posted on Jan 09, 2010
SOURCE: Ariston washer dial starts turning and won't stop -no wash/spin..
CHECK THE PIPE TO THE DRAIN HOSE AND FILTER TRAP IF ONE FITTED IF BLOCKED CAN CAUSE THE SAME THING ESPECALY IF YOU HAVE A NON RETURN VALVE FITTED
Top Ariston Technologies Washing Machines Experts
vince
ADMIN Andrew
ADMIN Andrew
Curt mueller
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
