Lands Phones Logo
A
Anonymous Posted on Jan 31, 2014
Loud static Portable phone was working fine. I returned it to its base. A few minutes later, there was a single loud beep. When I punched talk, very loud static. I could hear a dial tone faintly in distance. I called the number to see if the other phone in house still worked. It did. Replaced Clarity with new rechargeable batteries. Still same loud static. All connections are the same. No additional appliances at charger outlet.
T Tatro
Level 1:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 20 Answers
  • Posted on Jun 19, 2019
T Tatro
Contributor
Level 1:
Greenhorn:
Cheetah:
Answers
20
Questions
0
Helped
4698
Points
38
Remove the batteries let them discharge over night. Place in chargers for 24 hours. If still static unplug all phones from all jacks. Plug in a phone...a different one from the cordless ones. to make sure the static is not on the line.
You can then try to replace the rechargeable batteries or get a new phone.
5 Related Answers
A
Anonymous
  • Posted on Sep 18, 2007
SOURCE: Handset No Link To Base error and no dial tone
My battery is a Ni-Cd. I bought it new on eBay (TL26554 battery number). I allowed the new battery to charge for a long time and then tried to see if it would work. But no go....the handset gave me the same error message. Good Luck to you too! Mmmmmm
Anonymous
  • 106 Answers
  • Posted on Feb 18, 2008
SOURCE: handset does not work
Your handset is no longer communicating with your base. Depending on your model, the solutions can be a couple of different options. If I could view pdf files on this computer I would look it up for you. But here is the link to the manual on Unidens website- http://www.uniden.com/pdf/TRU8865-2om.pdf
Nonetheless, give this a try. Power down your base, and pull the battery out of your handset. Plug the battery back in the handset and set the bad handset in the base cradle, and then power up the base. Wait about 30 seconds, then give the phone a try. If it still does not work, then you need to try to "re-register" the bad handset back to the base. Look in the manual under "registration" procedures. Hope my help fixes it for you. Good Luck, CG
A
Anonymous
  • Posted on Feb 29, 2008
SOURCE: Handset ?No Link To Base? error and no dial tone
2/29 Have you registered or re-registered the handset?
"No link" can mean handset is not accepting radio wave of base unit. At Mfgr website pull-down operator's manual and look for registration instructions. Some sequence of buttons will create a radio signal from base (have handset off base) then another sequence of buttons on handset will accept radio signal. If handset has "menu" button, try "menu", then "00" (zero zero) then select an accept or "OK" button. Good luck.
Anonymous
  • Posted on Nov 14, 2009
SOURCE: Cannot hear any dial tone, but base works OK - callers get busy s
Headset says ringer off, cannot hear dial tone
Anonymous
  • 160 Answers
  • Posted on Apr 19, 2010
SOURCE: Has new battery, but no dial-tone,
Replacing the battery reset the phone to the factory defaults, which means you'll have to restore the connection to the base in Menu-Setup
***Don't forget to VOTE for the guys who take an interest in helping!
Top Clarity Lands Phones Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Clarity Lands Phone Expert? Answer questions, earn points and help others
