I have the trust ecoza 15082 webcam and it works fine on my windows 7 laptop but it will not work with my windows 8.1 desktop pc. i've downloaded the drivers and tried everything on the troubleshooting website but nothings working. the light turns on for like 5 seconds then off again...
SOURCE: a4tech pk-635m webcam not working on vista
Normal
0
Try
disconnecting the Camera from the USB port and reinstall the CD or
Downloaded software program. When the program asks you to connect
the camera to the USB port, do so and it should work.
Then
to use it on the Web do this.
Web Camera’s have to be
setup on the program they are to be used with. Just installing the camera
on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for
the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/
) set it up as follows:
The camera and audio should function properly. Your
friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger
(http://www.soft32.com/download_30.html
C. Windows Live Messenger:
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so
you can chat and see family or friends you are connected to.
Hope this helps. Bud
SOURCE: webcam driver
http://driver-pro.com/related/english/device-driver-updates/?gclid=CKDu0MmZ45oCFQzxDAodYFZVCA&hit=1&adurl=15809
Hey may be this can help you. It says Infoscape PC camera.
Good luck !
SOURCE: PC don't detect my Ucom webcam.i 've installed the driver.
Have you tried running the XL driver in compatibility mode ?
SOURCE: Trying to install Labtec drivers for my labtec
You can contact Labtech from here
http://www.labtec.com/index.cfm/service/splash/AMR/EN,CRID=3
You may have to run it in Compatibility mode if Windows 7 webcam software is not available - I'm sure they can advise you
To navigate to CM on my logitech I rightclick the webcam shortcut icon on the desktop and click 'Properties' and then the 'Compatibility' tab.
SOURCE: a4tech webcam PK 710MJ not detected in win 7
Follow the instructions below and it will work.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program.
When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the
camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
http://www.soft32.com/download_30.HTML
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
http://download.live.com/Messenger
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
Conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends.
