Cooktops Logo
A
Anonymous Posted on Jan 25, 2014
Kitchenaidstove top ignition problem - KitchenAid Cooktops
Marat Brikov
Level 3:
Director Badge:
Uploaded 100 video answers.
  • KitchenAid Master 518 Answers
  • Posted on Mar 21, 2015
Marat Brikov
KitchenAid Master
Level 3:
Director Badge:
Answers
518
Questions
0
Helped
329870
Points
3123
Everything about It.. Thanks for watching
1helpful
2answers
Gas cook top makes the ticking sound
sticking or faulty igniter
Aug 19, 2019 • Cooktops
Gas Kleenmaid cook top, one igniter continues to
the switch for the ignitor is stuck. might need to free the switch, of
> call the repair man.
All the igniters are clicking after cleaning - help!
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Spark igniters continue to spark:
let it all dry out
thumbs up
Aug 17, 2009 • Cooktops
I cleaned the gas top and the two left side burners do not ignite
Take the burners out, then take a needle and stick in the small hole where the gas comes thru.
4helpful
My ignitor on my ge cooktop keeps clicking slowly in off mode
As it relates to 5 burner gas cooktop Model Number JGP 963SEJ1SS
First - Ignite the flame then reduce the flame to between low and medium.  If the igniter continues to click, you most likely have a contact switch issue related to the problem burner.
Unplug the cook top and turn off the gas.  After the gas is turned off, disconnect the gas line.
Remove the cook top.
Unscrew and Remove ALL of the burner bases by lifting them up.  The ceramic igniters may be difficult to remove but they will come loose if worked out slowly.
Pull of the wire connected to the igniter.
Remove to cook top top plate from the base, exposing the internal gas valves and wiring.
All of the burners are wired in parallel.   Lift off and unsnap the casing of the problem igniter switch.  The repair may require something as simple as, 1- cleaning the contact strips, or 2- slightly bending the non stationary contact strip to keep it from coming in contact with the stationary contact when in the off position, or 3- replacing the switch.
Unless you comfortable and understand how electric systems and switches work, this is a job for a qualified repair person.
Apr 02, 2009 • GE Cooktops
Does not ignite
Check to make sure that the gas is getting to the igniter. If you can ignite with a lighter or match, than the igniter itself needs to be replaced.
2helpful
Stove top ignition doesn't stop ticking
My Dacor cooktop had a similar problem of continuously clicking igniters. I unplugged it a couple months ago and used a piezoelectric igniter to get it started. Then I looked in the Dacor FAQ and it said to clean the ceramic igniter posts with alcohol not water. I had to scrape some gunk off a couple of the posts with a knife before cleaning with alcohol. Now it works.'
I think the igniters use electrical conductivity to detect when they need to spark, so even slight invisible contamination on the igniter insulator can confuse the sensing system. Also they all seem to fire as a group, so all of them need to be clean because if any one of them is dirty then they will all malfunction.
1helpful
KitchenAid KGCS100SAL0 Gas Range Top, one igniter doesn't work
change the ignighter switch they are mounted to the front of the knobs and must be changed as a set they look like square plastic boxes after you remove the knobs and pull the panel off the front
Top KitchenAid Cooktops Experts
vince
john h
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
