The plugs have seperated so need to find out what order they should be connected L-OUT L-RET R-OUT R-RET MIC-IN MIC-VCC GROUND 1 GROUND 1+D 1-D 1+5V
SOURCE: case wire two mother board
Here is your front Audio guide:
http://www.fixya.com/uploads/images/3C3CD07.jpg
Here is your USB guide:
http://www.marnscda.com/Guide/USBPinMB.jpg
And here is your front Panel guide:
http://www.elhvb.com/mboards/intel/pinout-OEM-Intel-2x9pin.jpg
Let me know how that works out. The front panel guide is rotated 180 degrees however.
SOURCE: usb connection wires from front panel to motherboard
The header plug is 9 pins, 5 on one side and 4 on other. Orient the header so that the missing pin is lower right and the connection left to right on top row and lower row are as follows. If you have a shield wire, do not connect this as it causes instability if the ninth pin is earthed. If you have no markings on the wires, you can test from the socket. Orient with the pins up looking from front socket and left to right is 1,2,3,4 same as header.
Pin Wire Color Function
1 Red V BUS (+5V)
2 White D-
3 Green D+
4 Black Ground
Testimonial: "was very helpful clear instructions both usb ports working 100% highly recommended"
SOURCE: JAUD1
download manual from here :
http://www.msi.com/index.php?func=downloadfile&dno=3989&type=manual
see on page 34 :
Front Panel Audio Connector: JAUD1
Note : The odd pins are on one side and the even ones on the other side.
SOURCE: Wires for USB go to which MoBo pins?
there is two sets of 4 pin on each with an xtra ground you may not use.
Here is the link for your motherboard manual which shows the connections.
i.e you can connect your two sets of 4 wires to usb 1 or split them i.e 1 set of 4 on usb 1 and 1 set of 4 on usb 2.
http://zhornyak.com/soyo/Soyo_P4X400_Manual.pdf
SOURCE: where do i connect front panel MIC POWER, MIC IN,
I've attache a picture to show you where the jumpers are located on the board, and an explaination of what gets plugged into what.
Good Luck
Thanks
Mark
