The Ice Maker stopped making Ice. Due to this happening previously, I replaced the water filter, which fixed this problem before, but not this time. Their was no water flowing into the ice tray. I then replaced the water valves. The Ice tray filled up, but then would not dump the ice. Thinking that the their was something jammed, a defrosted the freezer and got the ice out of the tray. While doing this the water kicked on and poured water into the freezer, but due to the tray not being in the proper location, it did not fill up the tray itself. When I replaced the tray, no water would fill the tray again. I unplugged the refrigerator for 10 minutes thinking it would re-set itself, but their is still no water filling the ice tray. The arm is down, and I do have water coming out of the dispenser, for glasses of water.
Thanks for the question There is a water valve just for the ice maker so the problem could be there if you have a volt meter you can check the valve what you can do to check the valve reverse the wires onthe valve and push your water dispenser if no water goes into your ice maker . you have a bad valve replace thanks for the question The appliance doc
ice tray wont fill with water so no ice. The cold water comes out with no problem. Is there a separate line that fills the ice tray ?
Ice maker issue
