HP Officejet 6600 e-All-in-One - multifunction  fax / copier / printer / scanner   color Logo
m
mcateetheres Posted on Jan 23, 2014
Error 386 will not fax out keep getting various errors 344 not 386
dave_willcox
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 24, 2014
dave_willcox
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
333
Points
Hi Error 344,
Is telling you the remote end has hung up the call which means it may not be a fax number (you called a voice line number for example, you can confirm if it as fax by just calling the number on your phone if you hear the whistles of a fax then that's not the cause).
I'm not familiar with the HP model but if it is "Super Group 3" (you can tell this if the transmission speed is capable of above 14.4kbps) and you're trying to call an older fax the remote machine may not be able to recognise the "Calling tone" your machine is sending and so it hangs up. You can try to remedy this by temporarily disabling Error Correction Mode (ECM) in your machines fax set up menu this will disable the Super Group 3 capabilities of the fax and maximum transmission speed will be reduced to the older Group 3 machine. HP website recommends the following:
Error Code: 344, 345, 346, 347, 348, 349 ECM, 350 ECM, 351 ECM, 352 ECM, 353 ECM, 354, 355 Definitions
  • The remote machine failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power-related problems.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote user pressed the Stop key while the reception was in progress.
  • Under rare conditions, incompatibility between the two machines might cause the remote machine to abandon the call.
Solutions
  • Retryt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
  • Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved.
  • Try sending at a lower transmission speed.
Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
1 Related Answer
Anonymous
  • 3085 Answers
  • Posted on Jun 06, 2009
SOURCE: fax series 920, can receive but not send faxes, error code 344*
Do you have or are you sending a fax to a party that has a DIGITAL PHONE SERVICE?
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
