SOURCE: connecting JABRA BLUETOOTH to MY SIDEKICK 3
Use your Bluetooth wireless headset or car speaker to make and receive calls: 1. Follow the manufacture's instructions for your Bluetooth device to make sure it is turned on and "visible". 2. From your Sidekick, go to the Phone application. 3. Make sure your Bluetooth device has paired with your Sidekick device by pressing MENU and selecting Settings > Pairing. (If you try to do this and you don't have Bluetooth services turned on, you will be prompted to turn it on.) 4. On the Pairing dialog that appears, make sure your Bluetooth device is listed and has a key icon next to it. The key means that it's paired with your device. If it doesn't have a key, roll the TRACKBALL to select the device name, then press to pair. Once paired, press DONE . 5. Back at the Phone screen, press MENU and select Transfer Sound to > Bluetooth Device Name. 6. Dial your number and send the call. All sounds will be routed through your Bluetooth device.
SOURCE: JABRA BT250V Hearing Problem
Cannot get my Jabra BT 250v to work with my Blackberry Curve 8310. Phone indicates I am paired, but there is no audio through earpiece. You can still hear audio through phone. Help.
SOURCE: Magicjack problems
Magicjack customers with problems need to but a
A/C USB adapter
This will help alot will cost you around $7.00
SOURCE: Can only use speakerphone to hear caller's voice on my iPhone
It's usually caused by a defective or dislodged electronic module that sits behind the ear speaker, this should be covered under warranty unless there are visible marks of the drop. If you're not covered, you can try a iphone repair guide websites, there are also places that sell iphone parts.
SOURCE: motorola bluetooth instructions n136 pair with IPhone
Your headset may also be called a HS850 (may look different) but the instructions would be the same. Instruction manual is here:
http://www.motorola.com/mdirect/manuals/HS850_%209489A97O.pdf
