I have a machine Kyocera km-2550 which has an error code c0960.
Defective DP main PWB. Device damage of EEPROM.
not so good fault this one - if you are an engineer prepare for the main PWB replacement and calibration that follow ( you could try as a last resort re-writing the firmware/ replacing the eeprom chip and re-writing)
if you are a customer- suggest you upgrade your printer to something else as it will be the cheaper option. Sorry for the bad news
SOURCE: I need to reset ID Code on Kyocera Mita KM-5530
The solution is easy! Push the Default Setting/Counter button on the top right side of the keyboard. Press the the Managment icon on the diplay. Enter 6-4-8-2 on the keyboard and select the Managment icon in the OFF position. Close all windows on the display and you should be ready to go.
SOURCE: Error Code C6050
First you must get into the service mode by keying in 10871087
The screen will start blinking - then key 163 and the screen should read cancel or execute -select execute
when it is complete turn unit off then back on and see if that worked, if not buy a new fuser unit. They cost around $150,00 to $200.00 depending on who you buy it from.
