Blenders Logo
A
Anonymous Posted on Jan 06, 2014
Instructions to set clock
Set clock
klassysassy5
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 09, 2014
klassysassy5
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1556
Points
I have a model SPC486A sharp travel alarm clock and I can't figure out how to set the date on it as I bought it and it didn't have a manual with it.
Why is my pressure cooker not running the length of time set?
You probably need to push set again or something when it appears you should be done. I have a slow cooker and they work that way. It appears to be running but you still need to push one more button or the program will stop after 15 minutes.
Help I need instruction manual for Kuhn Rikon HB988L hand blender and chopper set
Did you check with the company or e-mail the manufactor to see if they can help you?
Dec 31, 2012 • Blenders
The black rubber part that the glass sits on had broken right of the housing. Can a part be ordered or do i need to buy a new blender
It is very easy to fix. You will need a new coupler, which is part number 9704230. There is a set of instructions with video here:http://www.kaparts.co.uk/Howtoremoveablendercoupler/tabid/219/Default.aspx The part is available on Amazon as well as many other sites.
Filter replacement
Hi and welcome FixYa. I am Kelly.
I have to assume we are talking about a refrigerator. The question listing is under blenders and if so that is one fancy blender.
On most refrigerators the filter is in the lower left side of the floor grill. The will be lable that says press to release. Then you turn the filter cap counter clock wise to unlock the filter. When installing the new filter you must swap the cap from the old filter to the new one then press in hard and turn Clockwise until it locks in place. (see the instruction sheet with the new filter)
Thanks for using FixYa,
Kelly
Apr 24, 2010 • Blenders
7helpful
Rubber coupler on blender sheared off
Yes, it is very easy to fix. You will need a new coupler, which is part number 9704230. There is a set of instructions with video here: http://www.kaparts.co.uk/Howtoremoveablendercoupler/tabid/219/Default.aspx
Rubber coupling
Yes.
The coupler - the black cylindrical piece that juts up from the motor base, and it has 6 teeth protruding inward toward the center of it - is responsible for transferring motion from the motor into the blade assembly. You physically set your jar on top of it.
If you're needing a replacement coupler for your blender, you may order it and find repair instructions at the following link:
www.mendingshed.com/kacoupling.html
2helpful
Rubber drive wheel disintegrated. How do we replace?
The rubber wheel is known as the "coupler." To clarify: the coupler is a black, cylindrical rubber piece that juts out of the top of the motor base and you set the pitcher on top of it.
This part can be replaced through a Kitchenaid certified service center, where they can provide the part for you. It is a low-cost repair.
A listing of certified Kitchenaid locations may be found here:
http://caservice.kitchenaid.com/
Also, if you are interested in self repair, you may order the part and view do-it-yourself instructions here:
http://www.mendingshed.com/kacoupling.html
Top Oster Blenders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ADMIN Andrew
ADMIN Andrew
Mike Cairns
Mike Cairns
Are you an Oster Blender Expert? Answer questions, earn points and help others
