What you need to do is start a fire in the small side and have all your vents fully open. When the temp gauge gets between 150 and 250 you can add the type of meat you are going to smoke. You can add wood chips every hour to get that smoky flavor into your meat. You must maintain a low temp in order to get the best results. I usually smoke at 200 degrees from 5 to 12 hours long depending on what type of meat you are smoking. You must control the heat with the vents on the fire box side and also the exhaust where the smoke comes out. It takes a little practice but it is well worth it. You can also go to www.smokingmeat.com and they have a whole bunch of tips on how to use different types of smokers, rubs, sauces, meats and so forth. Good Luck and happy smoking
It was very helpful to me ....keith grey new zealand
Purchased a smoker with firebox on the side. I need instructions on how ti use
need smoking manuel
I'm having the same problem. I've done 3 beef briskets, the temperature reading says 220 but after 7 hours, my 5 pound brisket was only at 130/internal temp. At the moment, I've had a whole chicken in the smoker - it's been over 3 hours and the internal temp is only 135 !!! I've tried two different BBQ thermometers - could they both be wrong ? What's going on - HELP !!!
I have never used a smoker before and need help getting started
I have just got a smoker from a friend but do not know how to use it it is like the one show. can you help me on how to get start'd. also how much charcoal or wood is to be used.
my food is not getting up to temp what is going wrong help
how to use a smoker
