SOURCE: maytag gemini M# MER6769BAQ
Turn off the circuit breaker to the oven for a minute. This will reset it. This little trick works on most ovens that are locked. The oven should cool for at least two hours before doing this. Let me know if this works. Because there is still an issue of it locking again
SOURCE: Maytag stove with a F 1-3 fault
Have seen lock motors go bad on these. Probably happened due to self clean heat.
SOURCE: Admiral electric range with self cleaning oven
There is an automatic lock feature on this unit that after 1 hour will unlock itself.
hope that helps!
SOURCE: maytag top oven lock won't lock
Do you get any error codes? What shows on the display when you try? does it make any noises , like it is trying to lock? Is it a manual lock with a lever?
SOURCE: F9 on Maytag range MGS5770ADB
Try unplugging the oven from the electrical power. May release the
lock, which is held in place by a tiny micro switch. If not and while
the electric is still off or the oven is unplugged, use a bright light
flashlight to look through the slot where the lock is in the oven, not
in the door.
You may be able to use a thin blade screwdriver to move the lock to the
release position. Check the angle of the lever. A slightly bent lever
handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to
access the locking device and release it. May have to disconnect the
wires to the lock which will allow door to function but not during any
self cleaning modes.
