Proview HV-177 17 in. HD-Ready LCD Television Logo
Posted on Oct 17, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HV-175 LCD The picture looks like it has "fallen" in that there is a big blue band running across the top of the screen. Also, when I hit "display" the numerals appear to be ghosted and doubled. Any thoughts?
  • francyjig May 31, 2008
    Same problem but i would like to know where i might buy a JS 6AM 13F2 tuner for the Proview HV-177 17 inch.
    Nanacy
Anonymous
Level 2:
Novelist:
  • Expert 69 Answers
  • Posted on Oct 17, 2007
Anonymous
Expert
Level 2:
Novelist:
Answers
69
Questions
0
Helped
64015
Points
183
Picture quality problems (such as lines, fuzzy image, or wrong colors)
  1. Check the cables and connections: Make sure that cable connections are securely fastened to the connectors and try reaseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors. Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degredation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
  2. Check the  display issue with  a different channel. Picture quality problems on a single channel or on all channels may be caused by the TV station signal (antenna) or the cable signal source.
  3. Make sure that the image quality issue is not coming from your source signal. For example: if the image quality issues occur while viewing TV , switch the source to a DVD player to see if the image quality problems go away. If selecting a different input source (using the remote control) causes the problem to go away, troubleshoot the source device causing the problem - adjust aerial antennas, call the cable company for assistance, and . If a picture quality problem occurs on all sources, the TV or its settings may be the cause of the problem. NOTE: Higher resolution TVs will make it much easier to view signal problems coming from source signals - especially TV signals. For example, if your TV cable company experiences heavy load on their system, you may be able to detect small miscolored squares that briefly scatter across the screen (macro-blocking). On a smaller standard TV, this type of quality problem is much less noticeable on a standard TV, but can become very annoying when viewed with greater detail.
  4. Try to Reset the TV ( LCD) quality options. Please look in to User Guide to make the TV to factory Defaults..
  5. Unplug the TV from its power source. With the power cord unplugged, press and hold the power button for five seconds. Turn on the TV . If the image quality problems still exists across all types of signal sources, the TV should be serviced.
I hope that this should resolve the issue. However, if the issue still persists then please contact LCD manufacturer for further more on the issue.
Bye.
Top Proview Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
woodzowl307
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
