Vivitar ViviCam 5385 Digital Camera
I have one SD card that will not allow me to view the pictures I have taken, or move them over to my computer. When I try to open the file from the camera folder, it says "no preview available" and when I try to copy them to my hard drive, I get the message, "Cannot copy [filename]: the parameter is incorrect". I can see the files are there, but cannot view thumbnails or move them over. When I look at them on the camera (not connected to the PC and in view mode), I can see them just fine.
Any ideas?
Thanks
..wel, i solved mine.. im copying music files into a memory card like micro SD.. when im copying music.. it says.. cannot copy file.. the parameter is incorrect... then go into My Computer then Right Click the external hrd drive(micro SD),, then go to properties....then tools.. then click the Check now.. - it will check for some errors and automatically fix the errors.. :D thats it..
i hOpE So tHt ItS WoRk
YAAArr its not working now what should i do
oh no it didnt work for me. instead i now can't view my files in my micro sd and it's showing a message that it's not formatted. do i want to format it. i did not format it because i will lose all my data. what should i do?
Thanks alot for the solution! Worked perfectly!!!
The holding the sd card in a few seconds and then letting it click out to it's normal position worked for me but since my sd card reader on my eMachine is not a clickable one, I had to bridge with a Kingston sd card reader to USB. Putting the card directly into the pc gave me the same old 'incorrect parameter', 'device not ready' problems. Placing the card in the Kingston reader and then plugging it in, showed no media at all, but clicking the card into the reader and holding, while the reader was plugged into the pc, did the trick. I can now use any sd card and replace and remove files at will, including seeing properties and changing filenames of files on the card. I have the Kingston TravelLite SD/MMC reader if you want to make sure to get a 'clickable' one. Of course, you have to use care when clicking the reader whilst plugged into the machine so you don't break the usb port. I have tried many more technically posh things to solve this maddening problem but this simple thing finally did it. Thanks for the info here!
I cannot believe it but I just solved my problem. I have a Gateway Laptop with the Texas Instruments TIxx21 card reader. At some point it stopped reading SD cards and would give me an Incorrect parameter cannot copy error. I could not copy to or from. My fix is so simple and I hope it works for all of you. I push the card in all the way and wait a few seconds, then I let it click back into position and the images and files work perfectly!
The Best way i recovered my photo's is connect your Camera with your pc.
Go to My Computer. Click right on the disk of your Camera and go to properties.
Than go to the tab Tools. Than you will see an option for Error-checking.
Click on the button Check now... You will be promted to start the error checking.
Make sure u select both options --> Automatically fix file system errors and Scan and attemt recovery for bad sectors.
After that click start....... See the magic happen ;-)
Mvg,
Avinash Bhageloe
I had the same problem, which is how i found this page. i ended up going to sandisk.com and upgrading my readers firmware version- and now things are working beautifully!
Hi,friends i bought a 2gb micro sd and convert to 4gb micro sd by using the software driver increaser and i copy any to mocro sd CANNOT COPT THE PARAMETR IS INCORRECT both are same problem
CHEERS AND ENJOY THE PROBLEM
SOLUTION:BACK UP YOUR FILES AND PLEASE FORMAT YOUR SD CARD OR ANYTHING
You guys are awesome! Thank you very BIG! I was copying all my the files (BIG) from the compact flash card to the desktop's external hard drive and got a message that a certain file's parameter is incorrect...
I tried the USB reader and wallllaahhh! all uncopied pictures came out the way it should be! I am so thankful to all the contributors of this forum and most of all to your website. GREAT JOB!!!
I've had the same problem trying to transfer pdf files between my desktop and laptop via a memory stick. The desktop will read the stick files, but the laptop gave the error, yet they are both using XP pro. I recopied onto the stick and the laptop then read without error. I can only assume that the laptop driver had a problem with a read error.
Solution: Recopy or try another PC to read it!
I had the same problem using a SD card reader and copying the sat nav data to My Docs, I wanted to make a back up of the sat nav maps. I zipped the folder that threw up the error and copied the zipped file to My Docs. Unzipped it and no problems. Still don't know why it worked the file was only 289mb.
Same problem... Read your stuff above and tried the SD-card in a camera instead of the "old" (2 years) computer. All pics are still there! Thanks guys!
First, i had this 'HTTP 400 bad request'.then, i solved it.but now, when i try to get into that website, it started giving me this 'The parameter is incorrect'. i'm really very desperate and didi not know what to do. so please help me.
It will be better you should purchase a new SD card. Here are some good SD cards. Hope you will like it.
1.
Kingston 64GB Canvas Select Plus SD (SDXC) Card U1, V10, 100MB/s R, 10MB/s W
2.
Kingston 32GB Canvas React Plus SD (SDHC) Card UHS-II, U3, V90, 300MB/s R, 260MB/s W
3.
Kingston 64GB Canvas Go Plus SD (SDXC) Card U3, V30, 170MB/s R, 70MB/s W
TO SOLVE THIS PROBLEM YOU GO THE FILES WHICH IS COPYING IN SD CARD AND MAKE NEW FOLDER ON THE COMPUTER SYSTEM DESKTOP . FIRST ALL FILES IS CUT AND PASTE INTO NEW FOLDER OF DESKTOP THEN CUT THE FOLDER FROM DESKTOP AND PASTE INTO EXTERNAL DRIVE OR SD CARD OR REMOVABLE DISK . SO IT IS COPY EASILY AND VERY SUITABLE WAY . ENJOY ...... AND GIVING MASSAGE TO ME................:)
You just saved me a lot of heartache! I'm at my computer in tears thinking I'd just lost about 400 very important pictures. I just took my SD card out of my computer's reader and into a USB SD reader and all is fine and dandy. Weird! And THANK YOU!!!!!!!!!!!!!!!!!!
Can you help me.. couze.. igot a problem in my server 2003..
it says incorrect parameters when i add a member of an organizational unit.. it cant add , but can delete...
that would be a big help.. thnx
Thanks guys - big help - I have a Sony DSCT200, had the same "incorrect parameter" issue when trying to copy over
Opening the battery/card cover and pushing in the SD card actually worked - can't believe it, goes against all my technical beliefs! Anyway am going to backup up my successfully transferred pics, then try formatting the card and updating the software, hopefully that'll prevent it happening again in future.
the parameter is incorrect. i cannot copy my photos.
what should I do?
I can view my photos on the camera but can not transfer them to the PC says incorrect parameter, The card is a 2G card any suggestions?
I have exactly the same symptoms but my camera is a 1-gig
Sony Cyber-Shot DSC-P73. I'd like to know what's going on.
The new camera card I just bought even after I formatted it still reads"Card Error"on the monitor. Is there something else I can do before concluding my camera not working correctly or that I bought the wrong card.
Thanks
I have the same problem, but I am not using a SD card, I am using a Memory Stick PRO Duo for my PSP.
Memory stick pro says incorrect parameter, can't copy, can't move, but can view pictures only in thumbnails. Any help to save my pictures?
I am having the same problem with a Olympus camera using a 512mb XD card, however I can view the thumbnails on the camera (through explorer), just not copy or open the files.
It might make a difference that the camera's own viewer (when disconnected from PC) can view the photos perfectly fine.
I bought 16 gb micro sd card for my cell phone, I transfer music and fotos from old card to this new card, first it did OK, all the sudden it stops, saying that could not make a copy of certains files, I click OK,then retried to transfer difference songs to the card,thi time it said: card has writing protection, I push the button up to UNLOCK position, tried again.This time it said: can not copy( files name), parameter is incorrect. I read throught all posts on this page, tried to fix it, but still didnt work, still saying :parameter is incorrect... PLEASE HELP. Thanks.
need help ... unable to open wmv. videos in my emails. error message states " incorrect parameters". thank you.
cannot copy nds games from sd card keeps giving the error message parameter is incorrect
Help me!
From my USB strick at my pic to copy my PC.When error The parameter is incorrect.Why?
