Hardware & Accessories Logo
A
Anonymous Posted on Dec 09, 2013
When I set my Electrical Program Timer Raintight Photoelectric Photo Electric Switch TM-018 timer to 2-8 hrs, the lights start blinking. At "on" they do not blink.
5 Related Answers
Anonymous
  • 351 Answers
  • Posted on May 06, 2010
SOURCE: connect switch and lights flash
This is the usual reaction of a timer when the line and load are swapped in making the connections . Review your connections and make sure that the power is connected to the line wires . usually black ,, and the light, is connected to the load side wires .. usually red.
A
Anonymous
  • Posted on Dec 19, 2010
SOURCE: Outdoor lights timer: Intermatic HB851 photo timer
Intermatic make HB51 timer.
If this is not your timer, then add a comment.
To set for ON at dusk, and off 8 hours later, rotate dial to the number 8.
Timer turns on automatically at dusk.
Timer set to 8 hours will start countdown when timer turns ON > and 8 hours later timer will turn off.
Make sure timer is turned away from lights so photo-eye doesn't receive feedback.
Feedback is when the photo eye gets too much light, and then timer thinks it's dawn, so lights turn off, and a moment later photo eye thinks it's dusk again and lights turn on again.
Feedback from lights will cause timer to reset the 8 hour countdown.
A car pulling in the driveway can cause feedback.
If the timer resets because of feedback, it begins the 8 hour countdown again, so the lights will not turn off until dawn.
You can test timer by putting black tape over photo eye, and then timer will turn on.
Set timer for 2 hours for example and then check if timer turned off 2 hours later.
If timer is not functioning correctly, then timer is defective.
A
Anonymous
  • Posted on Feb 05, 2011
SOURCE: how do i set my model hb31r raintight timer for
Open following link to identify timer and download manual:
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/electromechanical%20timers/hb31r.aspx
Manual has too many words than fixya allows for free answer.
So I cannot copy manual here.
However you can add a comment any time and say exactly where the manual is confusing. I will respond back and help if possible.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Anonymous
  • Posted on Oct 29, 2011
SOURCE: Westinghouse photoelectric switch 28KC,# E257484 outdoor timer.
Here is the manual!
The Westinghouse 28451 is the exact same timer. I found the manual online.
Enjoy!!
Gene Haynes
  • 5391 Answers
  • Posted on Oct 18, 2012
SOURCE: stanley raintight outdoor 2 outlet timer instructions model # 28468
10-17-12
Copy following link, and scroll down page, to help identify same/similar timer and download outdoor timer manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Or add comment with clear description of timer, saying how it differs from timers shown on link above.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Testimonial: "Thanks Gene! Exactly what I was looking for. Many timers listed, worth a look."
Top Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
