Logitech G930 Wireless Headset Logo
J
Johan Malmrud Posted on Dec 09, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Logitech G930 Echo problem
My headset is echoing even when I mute the mic on the logitech software/on the headset and the mic shines red which it usually does when the mic is muted. But I still hear myself in the headset. If i blow in the mic or speak close to the mic it echoes in headset, EVEN when sound is muted on my computer and the mic is muted. The headset is three days old, what the **** is this ****? I have tried disabling sound and disabling mic in sound interface, nothing works. Pretty sure I have the newest drivers aswell.
  • Johan Malmrud
    Johan Malmrud Dec 09, 2013
    Nvm, found and solved the problem after hours of configurating.
Level 3:
  • Logitech Master 19,190 Answers
  • Posted on Dec 09, 2013
Logitech Master
Level 3:
Answers
19190
Questions
0
Helped
4461784
Points
82280
Check the device manager for duplicate devices and make sure that the on board devices are disabled
5 Related Answers
A
Anonymous
  • Posted on Aug 01, 2007
SOURCE: Cant Speak On Logitech Internet Chat Headset
Check the plugs on the computer. I have this same headset, and when I first gt it I had made the silliest mistake of not turning it on. A friend of mine had a similar problem, but with the sound. What had happened was, he was doing some cleaning up by deleting useless programs. He had seen a file, but htought it was useless, so deleted that. Later, the sound dn't work, and he had realized that program he deleted was the entire sound file. Maybe the same thing happened, and if it did, you may want to try to get a computer technologist to format your computer, which is basically just you load all of your files onto CDs, back-up hard-drives, or on another computer. Then, they will hack into the computer and make it so that it's almost as if it had just came out of the packaging, and it doesn't know your name or anything. After that, you re-load all the data back on.
Ekse
  • 13435 Answers
  • Posted on Apr 28, 2008
SOURCE: my logitech usb headset dnt work
your program is probably set to use the wrong input for the mic, check your settings.
Anonymous
  • 744 Answers
  • Posted on Feb 08, 2009
SOURCE: logitech headset not working
did u connect both the output wires from ur headset to ur system audio port.?
Anonymous
  • 118 Answers
  • Posted on Jul 18, 2009
SOURCE: headset and mic problem
may be codec issue unistall the sound card from device manager and reboot the pc then test again.
Anonymous
  • 250 Answers
  • Posted on Jun 09, 2010
SOURCE: logitec250headset mic not working at all on this pc
Hi, Please uninstall any logitech software version present on your OS - Then please proceed to clean boot. ( http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=228 ) -> Unplug all the USB devices connected to the computer ( Less keyboard + mouse ) please use corded kbd+mouse if possible rather than a cordless device. -> Go to device manager -> Delete all the USB HOST CONTROLLER -- All of them -- -> The host controller might reinstall them itslef, let the computer handle the reinstallation -> If the computer does not reinstall the host controllers, trigger the detection using the DM function " Scan for new hardware " ( The computer with magnifier icon ) -> Once reinstalled, clean boot -> Reinstall the software if available and/or plug the hardware when needed. -> Should work.
This TB delete the usb ports " memory " means if a device as been previously flagged with error, it will redetect the device without the flag, unless there is some serious issue with the hardware/OS
If after this the issue persist, then I suggest you to call Logitech support to issue a replacement, hardware failures are covered by warranty terms
US/Canada support: http://www.logitech.com/en-us/contact
European support: http://www.logitech.com/en-gb/contact
Thanks and have a nice day ! J -
Top Logitech Radio Communications Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
