Computers & Internet Logo
Timothy Swedberg Posted on Dec 08, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Screen dimmed The screen works for about 1 second then dims. I can change it from DVI to RGB, then return it to DVI and it works for another second, then dims again. It used to work after doing that 3 times, then 8 times. Now it does not ever 'warm up'. Not sure what is going on.
Gizmo5000
Level 2:
  • Expert 75 Answers
  • Posted on Dec 08, 2013
Gizmo5000
Expert
Level 2:
Answers
75
Questions
0
Helped
11386
Points
143
The monitor is going bad. The capacitors that drive the screen are getting weak. It is too expensive to fix, you'll need a new monitor.
5 Related Answers
Anonymous
  • 1066 Answers
  • Posted on Apr 03, 2009
SOURCE: Computer Monitor is dim
Time for a new flat screen monitor...The power supply is on it's last legs.
Anonymous
  • 152 Answers
  • Posted on Apr 04, 2009
mzsouthpole9, Yes, this sounds exactly like a SWITCH-MODE-POWER-SUPPLY problem, and/or INVERTER circuit problem. I have lucked out and repaired 3 lcd/fpd monitors with very similar/same complaint. Now here is what you are dealing with. Have you seen the new energy saving 'curlie-Q' screw-in Compact-Fluorescent light bulbs? Your lcd monitor needs white light to light-up all the pretty colors in the LCD panel. You are lucky. The SMPS in your unit is at least for now, supplying voltage to the digital processor board in your monitor. That's y u see an image on the screen. Because your Cold-Cathode-Fluorescent tubes (2ea) are not lighting-up, you now see what you see. this most likely is a SMPS failing to source voltage to the Inverter circuit which takes 12-20v dc and changes it to 800-1500v ac to light the thin, straight, horizontal (left to right) CCF TUBES. Here are your options as a consumer. Call viewsonic, see if they have a swapout program. You send them your's+$50-$90, and they send you a refurbished same model in return. Or try to find local TV/Monitor repair shop that knows forwards and backwards everything about CCF tubes and SMPS/INVERTER repair. Last thing is try to repair it yourself. Whatever you decide to do, please drop an email to me. I'm louie12fix on fixya or lmistyrel@ aol.com. Hope this info was of some help. PS Put LCD/FPD in safe place to prevent damage to the most costly part. the LCD panel!!!!
Anonymous
  • Posted on May 14, 2009
SOURCE: apple 23 monitor 3 blinks and then pause, top screen is dim.
I have an older 20" display. I have had this same problem on occasion, and coincidentally, just experienced it again this morning. It seems to occur after I do an OS update. I powered down the computer, disconnected the display, reconnected by pushing firmly into place, then powered up. The flashing stopped and the display works fine. You might have a different problem, but that simple solution worked for me.
Buddy Mcsparrin
  • 1684 Answers
  • Posted on Aug 05, 2009
SOURCE: dim monitar with flickering screen
The problem can be caused by 1 of 2 things either your power supply is going out or the backlight bulbs are going out. The most likely cause is the power supply. If you are willing to do a little soldering you should be able to do the repair. If you go to our web site at: www.ccl-la.com/badcaps.htm We have a section on monitor repair. Look under the Samsung 930B it is the same as your monitor.
If you don't want to do it yourself we do offer a repair service, email me if you are in need of that.
I hope this helps.
Buddy
Anonymous
  • 32 Answers
  • Posted on Sep 12, 2009
SOURCE: screen is dim barely can see desktop in background
Usually this is a problem with the backlight, or inverter. Most of the time the inverter is the problem which is a pretty cheap fix. If its the backlight, then you will have to replace the lcd, which is much more expensive.
Normally this is caused by the power inverter for the lcd2.gif. It is a small circuit board right below the lcd, that powers the backlight. If you take off the front bezel of the laptop you should be able to see it, it will have a 2 wire power cord coming out the one end, and another plug in2.gif on the other end with several wires.
Check ebay for a replacment but make sure you get an identical model as the one you have, as they are very specific to each laptop. The inverter will have the part number written on it.
Top Soyo Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
